Kyocera Taskalfa 5501i -c6610 error
  • daveh12
    • Jul 2012
    • 157
    [Error Code] Kyocera Taskalfa 5501i -c6610 error
    Hi all
    hope you can help me with this problem. I have a machine Kyocera Taskalfa 5501i that giving an error C6610. The service states it's a toner release motor,
    First of all I went to reset fuser error U163, but this option was not in the maintenance mode ????
    I have replaced the fuser, this didn't fix it. But I cannot be sure this didn't fix it because I cannot reset the error. Please help.
    Has anyone seen this before?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1901
    Re: Kyocera Taskalfa 5501i -c6610 error
    Did you try 906 ? It shows that machine has 163 in the service manual.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • daveh12
      • Jul 2012
      • 157
      I think it might actually be gone on the newer models. Any experience with the fuser release motor? Nothing in the service manual really about it, not sure what it even looks like.
      • daveh12
        • Jul 2012
        • 157
        Yes tried U906. No joy
        • tmaged
          • Oct 2008
          • 1901
          Swapping the fuser should have resolved it. The pressure release motor is in the fusing unit as well as the sensor.
          Hope that helps !
          -Tony
          www.dtios.com
          • daveh12
            • Jul 2012
            • 157
            Ah so those parts are in a new fuser. Connections are testing okay, so could be looking at a new engine PWB then. Unless there is something else I'm missing. Firmware is up to date etc.
              • 23010
              The fusing release motor applies fixing pressure when printing starts, then releases pressure when the print job is complete. There is a U163, and it is for resetting fuser errors.
              So, if that simulation is not available to you you may very well have an engine board problem. The few times that I have seen this code it usually resets without parts replacement. And even when you do replace the fuser, the code still returns intermittently. You should be able to run the fuser release motor in sim U030. =^..^=
              • Hose1cook
                Defective Technician
                • Jun 2008
                • 80
                Originally posted by daveh12
                Hi all
                Yes, when I installed a 5500 fuser in a 5501 by mistake, there was no U163 in maintenance mode then either.
                • daveh12
                  • Jul 2012
                  • 157
                  Yes the brand new fuser I tried was from the Mk-6305 (silly me) I noticed this earlier and I am going to try MK-6315 fuser. Wasn't sure if this would solve it though. Feeling a bit more confident now 👍. Let you know how it goes, thanks for the advice.
                  • jmaister
                    certified scrub
                    • Aug 2010
                    • 755
                    yep, fuser now has subtle difference. happened to me as well, the c6610 and the u163 not available.
                    Idling colour developers are not healthy developers.
                    • helms44
                      • 3
                      We had to replace the engine board and the fuser at the same time.
                      Hi all
