3051ci after a calibration 2 bands down copy
  • T_foot2
    • Nov 2011
    • 22
    After a Calibration or toner curve adjustment cycle machine leaves 2 bands 1 inch in on both edges of the next few copies and they are about 1/2 inch wide. You can see colors in the band on first copy then its all brownest. Looks like belts not cleaning.
    Running sky shot or full color copies the are fine.
    Firmware is up to date. I've replaced the transfer belt and roller as will as main pwb. Vacuumed image units and cleaned laser glass.
  • Kyo fan
    • Dec 2013
    • 368
    Re: 3051ci after a calibration 2 bands down copy
    Post a sample where it's clearly visible.
    • T_foot2
      • Nov 2011
      • 22
      Samples of bands on copies after calibration or curve adjustment.
      • copydocinc
        • Mar 2015
        • 263
        I'm going after the charge rollers on this one. If not, then maybe the drums. Since you said full color copies are ok, I would go after the black first. The transfer belt, I think would put this stuff on the back side of the page, not the front.
        • Kyo fan
          • Dec 2013
          • 368
          This is coming from transfer belt, the question is why, since you already replaced it together with transfer roller. Color calibration happens on transfer belt, but in your case it fails to clean it off after its done. Do you have any C2770 codes in the event log? I would double check and clean/vacuum all the contacts inside that are touching the transfer belt.
            • 23009
            I agree with the others. Clearly the color registration marks on the primary transfer belt are not being cleaned off. It's fairly easy to remove and re-prime the primary transfer blade. You may find that there is some packing foam jammed up under the blade. =^..^=
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1890
              The guys are correct. Take out the primary belt, & you'll see it matches up perfectly the sensors.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • copydocinc
                • Mar 2015
                • 263
                Believe me, I'm not disputing the transfer belt as being the problem. I just want to learn.
                How are the stripes, that are not being cleaned off the transfer belt, printing on the front side of his pages, since
                it is the back of the page that faces the transfer belt ??
                • tmaged
                  • Oct 2008
                  • 1890
                  The image transferred to the paper comes from the primary belt below the fusing unit. This is where the patches come from & line up with the sensors for registration/process control.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • copydocinc
                    • Mar 2015
                    • 263
                    Holy crap, I just realized what you are saying, thank you!!
                    I was in the middle of a brain freeze, I guess. I've been working on so many
                    smaller color machines, that my brain was stuck on the paper riding with the transfer belt
                    as the image is being transferred and forgetting that on this one and many others, the image
                    is formed on the transfer belt first then transferred to the paper with the transfer roller.
                    I need to change my medication.
                    • T_foot2
                      • Nov 2011
                      • 22
                      It has NEW transfer belt and roller, I also removed the cleaning section and vacuumed both the old one and the new one. Once the copies/prints clean up it runs great till next calibration or toner curve( gray scale adjustment).
                      This is a new machine less than 1000 copies.
                        Hi
                        Does it have an attachment kit ak731?
                        The older km3050 had a problem with the supplied screws that mount the left hand side rails being too long and touching the transfer belt assy.
                        Its a long shot but you have ruled out the transfer belt and roller, so its something else.
                        • copydocinc
                          • Mar 2015
                          • 263
                          What do you think about running sim. 469 ??
                          • jmaister
                            certified scrub
                            • Aug 2010
                            • 755
                            I had a belts folded its own edges with similar print.
                            Idling colour developers are not healthy developers.
