CS 250ci intermintent quality problems
  • oldtech1
    • Mar 2008
    • 35
    [Misc] CS 250ci intermintent quality problems
    I've been having intermintent problems with this machine. note yellow toner guage missing on report. these problem are not always there they come and go on copies and prints. I have updated firmware. see attachments
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: CS 250ci intermintent quality problems
    If you're using OEM toner, the yellow RFID chip isn't being read. The other bands are from the registration/process control patches.
    More than likely, you'll need to replace the primary belt.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • oldtech1
      • Mar 2008
      • 35
      I replaced transfer belt still intermintent problems
        • 23010
        That still looks like transfer waste. Is the tube clogged? =^..^=
        • NeoMatrix
          Senior Tech.
          • 3513
          I haven't worked on Kyocera/Copystar model machine for ages.
          Looks like excess toner buildup on dev rollers. Does this machine do only black copy/printing?
          The colour dev tanks could be binding up causing excess toner problems also? Take the dev's units out and vacuum away any loose toner hanging around. Shake the dev units side-to-side or give the dev units a gentle hit with the palm of your hand to loosen any binding dev, then wind the dev rollers to check for even density.
          Did you replace the ITB with an entire new unit or refirb the old unit with a new belt?
          Have you done a Gray Scale calibration?
          HTH
            • 23010
            ... Did you replace the ITB with an entire new unit or refirb the old unit with a new belt? ...
            The primary transfer belt unit only comes as an assembly. I've had a few apart ... actually fixed one that had transfer roller shift codes. The others I just opened up to learn from. =^..^=
            • NeoMatrix
              Senior Tech.
              • 3513
              I've pulled a couple of these ITB units apart, not much fun. I've cleaned the ITB internal rollers and fixed CQ intermittant faults. Yes we've always replaced them with a new complete assembly.
