CS-4501i
  • ericruh
    • Jul 2025
    [CQ] CS-4501i
    I have a CS-4501i that a full PM has just been done on and it has background on the top and bottom of the page now. I've attatched an example. The background is not on the first couple prints, but from like page 4 and on until the job is complete. Also, the counters don't appear to be clearing for drum/dev in service mode. This is even after a firmware update. All the U mode procedures ran post PM instalation appear to execute normally. Any insite on what I could be overlooking is appreciated!
    • 23008
    Re: CS-4501i
    What is the repeat interval?
    It look to me like primary charge. Did you handle the primary charge or get some other sort of contaminant on the roller? I would take a few minutes to clean the primary with glass cleaner.
    The drum and developing unit are chipped, and should have reset themselves with no additional steps. =^..^=
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      Re: CS-4501i
      Are you using OEM toner....I have seen a few machines were off brand toner builds up on mag roller in dev unit....you can clean it up but it will not last long.IMG_20150812_113021.jpgIMG_20150812_113027.jpg
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      • ericruh
        Re: CS-4501i
        Thanks for feedback. It turns out that the overall maintenance counter was at 999,999 and conflicted with the parts counters from clearing out when the new OEM parts that were installed. Unfortunately a new drum and developer were needed to finally get the parts counters to clear after the maintenance counter was adjusted back to standard setting. Worked with Tech Support on this and we have to send both units that didn't clear back to get a credit based off machines serial number. Huge pain in the ass, but that is what it was.
