MFX 1200 Poor Copy Quality when Scanning on Platen or ADF
  • Doug James
    • Jan 2012
    • 935
    [CQ] MFX 1200 Poor Copy Quality when Scanning on Platen or ADF
    I cleaned the optics, changed the drum and toner. Prints fine when printing internal print jobs. Scan lamp seems to work OK. Reconnected connected strip wire harness from scanner. Any suggestions would be very helpful. Attached is an example...
  • scanmc
    • Mar 2015
    • 182
    Re: MFX 1200 Poor Copy Quality when Scanning on Platen or ADF
    First thing I would do is print out some type of internal report to see how the print quality looks. If same results then we different issue such as drum,transfer roller etc
    • Iowatech
      Not a service manager
      • 3930
      The first post says internal prints look fine.
      That being said, I don't work on Muratecs , but I do have a suggestion you may wish to consider:
      This looks like the CCD or contact sensor has some elements out. If they were blocked by dust, I think the lines would be black.
      If it is possible, try cleaning the connectors that attach to the CCD or contact scanner (maybe give them a good blast of air too in case I'm full of crap), and also if there is a white reference plate, make sure it actually is white.
      Otherwise, you may be looking at getting a new CCD assembly or scanner unit (if you have the guts to replace just the contact scanner and you succeed, you are a better person than me).
      • Doug James
        • Jan 2012
        • 935
        That's the conclusion I came to. Just told the customer that it's not worth fixing. I SO APPRECIATE YOUR HELP !!!
        • dc313zd
          • Feb 2016
          • 26
          Time for a new scanner/CCD a'ssy. Not uncommon on that old dog, they were rated for 1000 hours. Part number: D88A005040. Cost is $100.27 from Muratec
          • Ahmed Bushara
            • Mar 2015
            • 26
            Dear friend please clean the mirror on the exposure glass.
            Thanks and best regards
            Ahmed Bushara
            Electronic Engineering technician
            Mobile: +249-999198804 /+249-123198804
            • dc313zd
              • Feb 2016
              • 26
              That work's about 10% of the time. Due to age, the CCD breaks down, it's a common problem on the 1200.
              • faxgoddess
                • Apr 2012
                • 70
                Have you tried setting the background level? Setting, * , 0, 9, background level, enter.
                "The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather in a lack of will."
                --Vince Lombardi
                • Woxner
                  • Jul 2011
                  • 838
                  even though internal looks ok clean the print head bar
