muratec mfx 2830 radf
  • copierlady
    • 338
    Working on a muatec mfx 2830 radf that keeps indicating a jam on the last page of any scan. There really is no jam but the machine makes you lift the door and reset it everytime. The last sensor is sticking a little, but not everytime!
    and, it is not stuck down when you open the door to check the so called jam. Tried cleaning it, no help.
    Anybody ever had this happen? Thanks!
  • copytechman
    • Nov 2008
    • 942
    I too am dealing with one of these. Muratec says it may be the ds2 feeler inside the feedin side just before the scanner lens.. if your cust does a lot of scanning like mine does they say it can wear out and cause odd jamming issues. I'll update once my part(s) come in on wednesday. Jeez!
    Regards!
    A.
    • copierlady
      • 338
      THANKS.
      Thanks i'll be waiting to hear. I call tech support too but they wanted me to be standing at the machine and it is a long way from my shop. Thats when i posted here.
      • mo0651
        • 1054
        Order the feeler tech support told you about. Not expensive. Have replaced alot of these in the fax models. Compare the old to the new and you will see that there is not supposed to be a flat tip on the feeler. Also helps with registration issues.
        • copytechman
          • Nov 2008
          • 942
          Was just there, pulled the feeler (it comes out from the bottom of the df, its under the white metal plate (the plate pops off, then 1 screw holding the feeler +sensor in place)) added 2 layers of cut of cut to shape black tape and placed over the end.. it works MUCH better now (still waiting on the part)
          Regards!
          A.
          • copierlady
            • 338
            PART NUMBER
            Ok guys are we talking about part number- (da1112106x)
            thats # 105 on the break down (pg da1-0003) ? Thats the only "feeler" i see listed on here. Looks like a tiny little thing to replace too.
            • copytechman
              • Nov 2008
              • 942
              PN# DA1109906x (DA11099060) Feeler DS2
              Replaced it today... all is well.
              Regards!
              A.
