Fuser motor Oki MPS5502
  • Sharptech56
    • Feb 2016
    • 100
    [Error Code] Fuser motor Oki MPS5502
    Hi All
    Has anyone sucessfully replaced the fuser motor in a MPS5502 Oki MFP. I've been at it for a couple days and the thing just won't come out.
    Oki suggested replacing motor after 3 tries at replacing the fuser unit F101 and C4E3 error codes all the time.
    Re: Fuser motor Oki MPS5502
    Originally posted by Sharptech56
    Hi All
    you have to remove all boards.. you really don't have to remove the scanner to get the eject assy out..the manual covers pretty well. I have replaced one in the MB770 ( same as 5502) but it was a bear.. hidden screws and a PIA to do
      • 23009
      I was working on the Toshiba rebadge of this machine for jamming. I was fairly certain that the fuser was turning slowly, but could not decide between the fuser and the fuser motor.
      You can probably understand my relief when the fuser fixed it. Oddly, I could not find any difference between new and used fuser. In the short term I could set the used fuser to envelope pressure and it would feed.
      At one point I had every cover off this machine, and the darned exit section just did not want to come out. I do not envy you.
      • richs
        • Nov 2008
        • 265
        F101 is hard drive.Never had to replace a fuser motor but fusers on that machine go all the time.We get between 40K to 80K usually.C4E3 is a fuser lock error(fuser speed problem)We have replaced fuser on the MPS3537 for this code but have not done a motor yet.
          the exit is a B!tch to get out ... Oki tells us for the E010 jam code.. replace in order fuser - Eject ... but in most of the 20+ units of the MB760 or MPS5502 it has been the reg/hopper assmy... E010 is a catch all code for jams from pickup to eject.
