What Screwdriver Are You Using?
  • ariekazy
    • Aug 2025
    Just for discussions sake, what is everybody's go to screwdriver? I carried the long bladed Snap-On ratcheting for years, but I've recently swapped to Wiha and I'm VERY happy with those. Just needs knurling on the blade like Vessel does....
    So what are you guys carrying?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Re: What Screwdriver Are You Using?
    See pic. Panasonic EY7410 3.6-Volt Lithium-Ion. Light balanced. Battery lasts weeks! Adjustable torque. Put a dewalt magnetic bit holder on it and #2 phillip bit. To many screws on these digital machines to be turning screws by hand!
    • JR2ALTA
      • Feb 2010
      • 2033
      Nothing special here. just hate rubber grips because they snag in back pocket.
      • Blizzoo
        • Aug 2013
        • 608
        I'm using a Snap-On ratcheting for more than a year and I'm happy with it, I have lost it and recovered it shortly a few times, felt like loosing your wallet
        • Ratchet2501
          • Mar 2017
          • 206
          That, Knipex pliers and Klein screwdrivers. I'm luckier than most though on selection, we recently got a wholesale supplier out here. Even though my boss doesn't like my "bringing tools to work" but. . . . have to have good tools.
            • 23009
            Schroder 47473 re-badged as Craftsman. It's weighted heavier than most, so you get a lot of rotational momentum when spinning out screws. I'll probably jinx myself for saying it, but I've been using this same screwdriver for 15+ years:
            • Gavin_Parkes
              Long shaft Snap-on since 1986, 31 years and still going albeit a little shinier than it was!!
              • allan
                RTFM!!
                • 5462
                Wiha Ph2 * 300.
                Cant work with anything else.
                Whatever
                • mo0651
                  • 1054
                  Grey Goose and Minutemaid!! Helps to take the edge off!!!
                  • allan
                    RTFM!!
                    • 5462
                    No!
                    Beer is better!
                    Whatever
                    • roho
                      • Mar 2009
                      • 844
                      Harvey Wallbanger,
                      • habik
                        • 2013
                        I'm a Wiha man as well, until I got some taken one by one in my previous places. Got left with only #40 #50 Philips from precision set..but soon be looking for electric drive as my tennis wrist & elbow is kicking in more often. Currently my main drive is:
                        200mm Snap On solid...
                        Stumpy..#2 Philips
                        Backup 75 pence Philips to use mainly the polyamide handle wrapped in duster cloth to scrape soak rollers.
                        For the sake of having conversation about drives I'm thankful as I was looking for electrical and the Pana seems like a reasonable option!
                        Sent from portable device using fast cheapset!
                        Firmwares HERE
                        • Lagonda
                          • Aug 2008
                          • 1649
                          What ever bent, mangled and worn out driver that's left in my workshop after those thieving bastards of IT techs have "borrowed" the good ones without asking.
                          • Geo
                            • 662
                            Stumpy..#2 Philips
                            Hitachi model DB 3DL2 ... Comes with 2 batteries , adj torque setting , 2 speed 260/780 and the best part, rocker switch. At this point, can't live without it.
                            • kjg
                              • Mar 2009
                              • 112
                              Wera Kraftform Lasertips. my personal favorites.
