Connect a laptop to a printer directly with ethernet cable using Windows 10
  • deserttech99
    • Jun 2013
    • 33
    Okay, so this is an easy thing to do generally using a laptop with Windows 7 in order to test a network card.
    But every time I try to do it with a Windows 10 laptop it won't connect
    This is the path I'm using...Control panel > network and sharing > Local connection properties > TCP/IPv4 properties > set IP address to a different number [last octet] than the printer IP address. [example...printer IP is 192.168.0.80 so I set IPv4 properties IP on laptop to 192.168.0.81
    Subnet and default gateway are correct
    Get error "unable to connect"
    What's interesting is if I ping the printer IP, it keeps returning the error that "the IP address is not available" 4 times, but then shows 4 packets sent and 4 packets returned and "0" packets lost
    Any ideas what I'm missing?
    TIA
    DT
  • mincopier
    • Dec 2015
    • 289
    Re: Connect a laptop to a printer directly with ethernet cable using Windows 10
    Are you using a crossover cable or a patch cable. New laptops are supposed to have auto sensing network cards and can use a patch cord as a crossover cable.
    Other than that I have had no problems with my windows 10 computers connecting directly to a printer.
      • 23010
      Exactly like that. I always use the crossover, but my IT guy tells me it's entirely unnecessary. Maybe you need to re-boot the printer to get it recognized. =^..^=
      • deserttech99
        • Jun 2013
        • 33
        I am using a standard patch cable. Tried rebooting the printer and the laptop both but no help. Getting both the green LED and the amber LED on both ends, so there's an issue of some sort i can't figure out
        • copier tech
          • 8227
          Are you trying direct connection to troubleshoot an issue ?
          • deserttech99
            • Jun 2013
            • 33
            yes
              • 30558
              Turn off your wireless disable it
              do an ipconfig on you laptop to confirm the your ip address settings
              most laptop will auto switch so you don't need a crossover cable however I never connect that way. I always use a 5 port switch to confirm link lights and network cards are both active.
              • deserttech99
                • Jun 2013
                • 33
                Thanks.....i had tried those things too, but still won't work. Cannot even print a test page
                  • 30558
                  Can you ping the printer?
                  • deserttech99
                    • Jun 2013
                    • 33
                    yes
                      • 30558
                      Ok great that means computer sees the printer next what kind of printer is it?
                      You must download the correct printer driver from the manufacturer DO NOT USE WINDOWS DRIVERS!
                      Download and install it's a local printer if you need to set up a port use standard tcp/ip port 9100 raw and uncheck snmp box
                        • 23010
                        Several Konica Minolta models have a network interface, PageScope, and ping, but cannot print if they do not have the optional print server. I wasted an embarrassing amount of time on a bizhub 501 trying to get a print, but it was never going to without the option. =^..^=
                        • deserttech99
                          • Jun 2013
                          • 33
                          Well the update to this is I am still not getting anywhere.....
                          Trying to direct connect with a patch cable to an Oki MB470 using an Acer netbook with Windows 10 [32bit]. I want to pull up the printers web interface page using Chrome. [doesn't work with IE either]
                          The printer IP is:
                          IP address 192.168.0.80
                          Subnet 255.255.255.0
                          Default Gateway 192.168.0.1
                          Going into Network Sharing > Change Adapter settings > Unidentified Network > Properties . IPv4 Properties > IP address
                          I have entered 192.168.0.81 as an address for the netbook network setup in the TCP/IPv4 properties
                          Notes:
                          Wireless Network in Change Adapter settings is Disabled
                          Windows Firewall is Disabled
                          Correct printer driver was downloaded from Oki website and installed. In Devices and Printers it shows the MB470 installed with a green arrow showing it as the default printer.
                          Problems-
                          When I open chrome and type in "192.168.0.80" it gives the error "Unable to connect - the device took too long to respond"
                          When I send a Windows test page to the printer, I get the error "Error - unable to print test page" but no other info
                          Open Command Prompt and ping printer and it shows 4 packets sent, 4 packets received and 0 packets lost
                          Never had this problem using Windows 7 on my prior laptop
                            • 30558
                            What the IP address on the reply? If it's your laptop then it's not seeing the printer
                            some laptops will auto switch the network port to a crossover connection. If it's the laptop ip address then your laptop is NOT auto switching and you will need a switch or a crossover cable in order to connect to the printer.
                            • copier tech
                              • 8227
                              So are you saying you only have this issue on your laptop?
                              Have you tried another PC?
