Olivetti 6014
  • Brandon
    • Jun 2019
    • 72
    Olivetti 6014
    Good morning
    I have an Olivetti 6014MF that is giving me blank copies/prints , i have tried replacing the drum and dev unit with out any change , i have checked the pins/contacts inside device all are clean and in place , my last thoughts are heading to the HVT unless i have maybe missed something simple
  • KYO_OEM
    • Aug 2011
    • 725
    Re: Olivetti 6014
    laser shutter?
    Did you run printjob or else without main charger?
      • 23010
      Re: Olivetti 6014
      This looks a lot like a monochrome mono-component Kyocera. Did the developing unit come empty? Did you run the toner add function?
      • KYO_OEM
        • Aug 2011
        • 725
        Re: Olivetti 6014
        You are right Blackcat
        it`s KYO M3660idn with Olivetti Branding
        On "older" Polaris we have had problems with drive cluch for DVs, broken HVT, not working laser without C-Call...and so on
        System menue/ New Developer at first
        Checking drive for DV station
        Running test page without MC/ if no image on DK --> HVT
        • Brandon
          • Jun 2019
          • 72
          Re: Olivetti 6014
          if i run a print with out charge roller i get a black spotted page almost like a sky copy/print but not totally solid
          • KYO_OEM
            • Aug 2011
            • 725
            Re: Olivetti 6014
            In this case we must think about the laser at first.
            At the previous series we have had problems with the laser shutter, but this part wouldn`t mounted from factory anymore in the successor series.
            Sample from Printout without MC available?
            • Brandon
              • Jun 2019
              • 72
              Re: Olivetti 6014
              attached is a scanned sample
              • KYO_OEM
                • Aug 2011
                • 725
                • Brandon
                  • Jun 2019
                  • 72
                  Re: Olivetti 6014
                  i replaced the transfer roller and used another machines drum and dev units and results are still the same , i am suspecting a faulty high voltage board or faulty main board ?
                  • KYO_OEM
                    • Aug 2011
                    • 725
                    Re: Olivetti 6014
                    HVT, i think.
                    Sample looks like shortcut from HVT
                    • Brandon
                      • Jun 2019
                      • 72
                      Re: Olivetti 6014
                      HVT, i think.
                      thank you i was also thinking hvt is faulty or failing
                      thank you for your assistance
                        • 23010
                        Re: Olivetti 6014
                        Are you sure that's genuine Olivetti (Kyocera) toner? =^..^=
                        • Brandon
                          • Jun 2019
                          • 72
                          Re: Olivetti 6014
                          Are you sure that's genuine Kyocera toner? =^..^=
                          i have tried two other complete drum units from 2 different machines that sre working and still have the same issue
