Original remanufactured toners
  • savi0r
    • Sep 2010
    • 363
    [Misc] Original remanufactured toners
    Hello all. What do you think about this product? Is it a viable solution to OEM toners?
    (323) GM Technology. Remanufactured Original Toner - YouTube
    Re: Original remanufactured toners
    they cannot formulate the toner the same so I call BULLSHIT. I never liked "re manufactured" toners....
    nice sales pitch tho.. but bullshit
      • 37502
      Let's see, remanufactured toners? Does that mean taking waste toner and returning it to a usable form? Now I can see it maybe with black and white machines where all you have to do is remove any contaminates such as developer and paper lint. When it comes to color you have an entire new can of worms. Not only do you need to remove contaminates but you also have to separate individual toner particles by color.
      • copier tech
        • 8149
        It is simply not worth the risk, you may end up with dev units failing early then you'll end up making a loss, in some cases a HUGE loss.
        At a push I would consider MONO compatible toner but even then if it dumps everywhere inside the machine it will cause unnecessary issues.
        • savi0r
          • Sep 2010
          • 363
          • 40yearsplus
            • May 2020
            • 113
            Country Phone number code on website shows they are in Spain. If that's so there goes the 13 percent they say they will save you.
            Also may wait.......
            • savi0r
              • Sep 2010
              • 363
              Why do you say that? I mean about the 13%?
                The savings buying that crap toner.
                • savi0r
                  • Sep 2010
                  • 363
                  Oh, ok. Got it.
                  Thank you for your opinions.
                  • Vincent128
                    • Sep 2015
                    • 349
                    Never again will I be apart of a company that uses any aftermarket/refill/etc toner in any 2 part developer system..ever.
                    It's just not worth the increase in service issues and the decrease in yield of the imaging and related parts.
                    I'll never forget the absolute stupidity of our then service manager when I was a tech working on ricoh's and the 35/45 cpm POS machines. Some moron decided to AGAIN use NA trading junk ..."Hey these drums, developers and toners cost half as much"..."Yes but they only go half as long and explode in the machine making a big mess that destroys fusers and drive gears"..."Yes but 1/2 the cost! Just look at the savings!"
                    • savi0r
                      • Sep 2010
                      • 363
                      It seems OEM is still the only sure way to go.
                      • mloudy
                        • Oct 2015
                        • 787
                        When Sharp pulled authorization on one of the mega dealers years ago we were handed a few National Accounts and schools. I personally went to one school system and visited each building who let me know they HATED their copiers. After a string of questions it all came down to the changing of toners. Each building had multiple Sharps which had the stupid shutters that had to be pulled to add toner. The non-OEM toners that the dealer supplied would not release the shutter without monkeying about. After the teachers began installing Sharp toners their attitudes towards the copiers completely changed. It wasn't even the toner itself but the cartridge that was not right.
                        I have tested non-OEM toners over the years and all have EVENTUALLY failed. I've listened to all the testing these companies do and how they have Service Managers from companies with throusands of machines running their products that I can talk to. blah blah blah. I was sucked in again about two years ago trying to increase margins on a school system that beat us down to .0035 locked for 5 years. The toners I tried ran for 6 months without an issue with machines going through several toner per month. Then it all fell apart. Toner related error codes that we had never seen before and crap solids or overtoning. Never again (I've said that before )
                        • Drivee
                          • Nov 2020
                          • 322
                          OK, nice video.
                          I see that here that service engineers don't like remany toners. That is fine, I understand that, using OEM will make less problem as many remany toners are really crap and they coming from China and many countries which don't understand what is quality. I test a lot of them and 90% of them are crap.
                          We need to know that Canon dont make a toner and OPC's. It is all made in separate companies which make toner toner for remany companies as well. OEM toner or OPC no one can bay, it is just made for OEM but another version are available.
                          If we talk about copy tubes, YES, this is dangers. Toner can make life of DEV units shorter and OPC as well.
                          So, picking good toner is very expensive and it need a lot of tests, most remany companies don't want to do it and then problems acure. If we talk about small cartridges as HP505X or 26X, for sure there is good toners which can be used without any problem.
                          To go back to video which I saw. First, they cannot use OEM toner from OEM tubes as first, they don't have enough toner in tubes and empty cartridge is expensive. They need 15 cartridge to refill 1. Even if they try to do it, toner in tube is mixed with carrier. Carrier need to be in some %, depend of model. So, no way that they use OEM toner, it is just impossible.
                          Regarding marketing on video, I can bet that Canon will sue them as intellectual property here is broken. They cannot use Canon or OEM on their labels.
                          If I am someone why will take care about toners for some company, I would ask from them on written that they garanty same quality as OEM and if any problem jump up, they need to pay.
