Zebra first label sometimes only prints left side
  • boutn
    • Jun 2016
    • 540
    ZTC ZD421-203dpi ZPL
    Sometimes, the first page only prints the left side of the label.
    Its always the first label of the job, if it happens.
    Print speed has been adjusted.
  • Larhal
    • 564
    Communication Error?
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • boutn
      • Jun 2016
      • 540
      it prints, but the right side is missing of faded.
      See attachment
      • Larhal
        • 564
        Looks like the print head is not tensioned enouh on the one side. There are 2 adjustment screws on the top of the print head with springs. Tighten down on the side that is weak or missing.
        Larhal
        • boutn
          • Jun 2016
          • 540
          i only see a screw with some grounding cables.
          The tension on the print head comes from the metal bar you can see on the pictures. It pushed the head down in the centre.
          • Larhal
            • 564
            On top of the heater head there are tension adjustments for the heater head/print head. underneath the top cover/ Sometimes the latch that holds the print head down onto the ribbon becomes weak. You can try to wedge something under the latch to hold it tighter to the ribbon. They tend to lose their hold after long term use.
            Larhal
            • boutn
              • Jun 2016
              • 540
              The heater head is in the pictures i shared…there are no tension adjustments…and the printer is only 1 year old, so no long term use.
              • boutn
                • Jun 2016
                • 540
                Oh, and also, the labels are direct thermal, so no ribbon
                • Larhal
                  • 564
                  Ok Boutn, I have had experience on the older modles, sorry I could not help you.
                  Larhal
