Zebra first label sometimes only prints left side
  • boutn
    • Jun 2016
    • 537
    ZTC ZD421-203dpi ZPL
    Sometimes, the first page only prints the left side of the label.
    Its always the first label of the job, if it happens.
    Print speed has been adjusted.
  • Larhal
    Semi Retired
    • 533
    Communication Error?
    Larhal
    Retired Part Time
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • boutn
      • Jun 2016
      • 537
      it prints, but the right side is missing of faded.
      See attachment
      • Larhal
        Semi Retired
        • 533
        Looks like the print head is not tensioned enouh on the one side. There are 2 adjustment screws on the top of the print head with springs. Tighten down on the side that is weak or missing.
        Larhal
        Retired Part Time
        • boutn
          • Jun 2016
          • 537
          i only see a screw with some grounding cables.
          The tension on the print head comes from the metal bar you can see on the pictures. It pushed the head down in the centre.
          • Larhal
            Semi Retired
            • 533
            On top of the heater head there are tension adjustments for the heater head/print head. underneath the top cover/ Sometimes the latch that holds the print head down onto the ribbon becomes weak. You can try to wedge something under the latch to hold it tighter to the ribbon. They tend to lose their hold after long term use.
            Larhal
            Retired Part Time
            • boutn
              • Jun 2016
              • 537
              The heater head is in the pictures i shared…there are no tension adjustments…and the printer is only 1 year old, so no long term use.
              • boutn
                • Jun 2016
                • 537
                Oh, and also, the labels are direct thermal, so no ribbon
                • Larhal
                  Semi Retired
                  • 533
                  Ok Boutn, I have had experience on the older modles, sorry I could not help you.
                  Larhal
                  Retired Part Time
