imagistics IM3510
  • bcbs
    imagistics IM3510
    I have a imagistics Im3510 with error code L4-02. I checked the drum motor and after running a few seconds,it goes back to the code. any help?
  • Colour Engineer
    • Jun 2011
    • 7
    Re: imagistics IM3510
    Have you check the pawls in the fuser unit are not digging into the LFR as they are both driven off the same motor also it could be the bearing on the dev unit that has become sticky.
      • 23010
      Look into high voltage related leaks, specifically the high voltage cable that runs through the main drive pack to provide the primary charge. The main drive pack can cause it also.
      Since the cable is considered part of the main drive pack assembly, you cover both possibilities by replacing the main drive assembly. =^..^=
