DP-3510 Jamming J-40
  • Chickenlegs
    • Sep 2025
    [Jamming] DP-3510 Jamming J-40
    We have a DP-3510 (250K) that seems to have a J40 every 10 to 15 copies.
    The fuser has been upgraded, heat roller and web have been replace in the past (are good - less than 50k).
    I went to the unit, cleaned all transport belts and rollers.
    I ran 350 (from ADF) copies all fine, 250 from glass all fine.
    Called customer in the morning and they had 3 more J40 jams.
    Any ideas?
  • mojorolla
    The Wolf
    • 2639
    Re: DP-3510 Jamming J-40
    Make sure the paper is not too damp. Under the drum unit are 3 separator fingers that are fired by a solenoid on the rear frame. Make sure all 3 fingers are there and the solenoid is working. You can cheat the 2 front door switches and watch it run paper under the drum.
    • Chickenlegs
      Thanks Mojo
      Thought of that.
      All 3 fingers there, solenoid working. Even took my own paper, still had jams.
      Paper makes it half way from drum to fuser, that's why I was thinking transport unit. Have watched paper leave drum and enter fuser no problems. Looks smooth.
      Yes, did check bushings in transport.
      • mojorolla
        The Wolf
        • 2639
        Pull the main drawer out and check the timing belt on the back. The tension spring sometimes needs a lil goosing. I cat remember if that model has a suction fan in the transport, but if it does, make sure it is working.
        • ESTANISLAOWENENTON
          I step once
          broken wire separation
          again
          separation and transfer cases worn
          change and ready
          • copiman
            • Sep 2011
            • 861
            Originally posted by ESTANISLAOWENENTON
            I step once
            again
            change and ready
            THANKS for posting solution. Glad you got it.
            • 20gaugeO/U
              • 557
              Increase the Sep AC voltage 1 sided and 2 sided. If 3510 is the same as 60/80 series it's F6-58 and F6-60. It's what I've had to do if the customer uses heavily curled paper and it started to jam under the DRUM sep fingers.
