Ricoh 2045 Error code 322
  • clearimage
    I have a machine that is giving me a 322 laser code (1st laser synchronizationerror). Can i clean the laser unit? Replace the laser synchronization board, or replace the laser????Any thoughts ?
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    • clearimage
      Thank you very much. I will try blowing out the door switches and see if that works.
      • pbbsinc
        • Nov 2005
        • 92
        I've had quite a few b003/b004 and a few b079/b082 machines with this problem, & found none of ricohs suggestions helpful.
        Although I resist tweeking a pot until all else has failed, I have had quite a bit of success (80% ro better) tweeking the pots on these up just a little bit (one incrrement, maybe 2).
        We joke about smoke rolling off of the drums as the laser scorches the coating, but it hasn't happened yet.
        jay
