out of box blank image black only mp c4503
  • wyo19
    • Nov 2012
    • 51
    [CQ] out of box blank image black only mp c4503
    Brand new C4503 set up in shop worked PRO-CON 11111111 at setup. Delivered Machine no black at all only code SC 492 and PRO-CON 11111159. Tried PCDU in another machine works, I'm lucky to have a another machine(Brand new,but crushed) to pull parts and boards off of. These are the parts I've swapped out with no change:
    HVPS
    TTSPS
    CB PS
    DC PS
    ITB
    PTR
    PCDU
    IMAGE BCU
    K MOTOR PCU AND DEVELOPER
    BCU
    I Have narrowed it down to no "DEVELOPER BIAS" hence no image, now am at a crossroad as to what is causing it,maybe a harness or something to do with the connectors (2) that the pcdu contact when sliding.
    Any Help or direction would be appreciated...
    I will be trying a couple of things on Sunday Firmware, NVRAM clear.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: out of box blank image black only mp c4503
    Stay away from the NV ram clear, firmware is always a good thing to update, but probably not the issue. I would really look at the PCDU and the connections and end plates for this first. Did you try the PCDU from the donor machine?? If so did it do the same thing??
    Mystic Crystal Revelations
    • wyo19
      • Nov 2012
      • 51
      I upload all data then do a memory clear,since the machines never been in service. Don't need to backup address book.
      I used the PCDU from the "crazie" machine in a working machine, no problem. I think it could be the little spring in the back of the copier,will know more tomorrow.
      • copier tech
        • 8174
        If this is a brand new machine out of the box why don't you simply put in a DOA claim & save yourself the hassle!?
        Being a new machine it could be any number of things.
        • duct tape
          • Jun 2009
          • 87
          How about the black transfer roller in the it the itb unit I've seen different colors do that the roller can come unmounted.
          • wyo19
            • Nov 2012
            • 51
            I've tried swapping out with another ITB assembly, and there is no image on the drum
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              In that vast list of swapped parts I didn't notice laser?
              Have you tried a different laser assy?
              Could be that the black pcb has shat itself...sounds like the laser is not writing for black.
              What happens if you try to do an ACC or run music?
              Does it fail?
              Does it throw a density code?
              Questions questions questions lol.
              • slot
                • Jul 2008
                • 341
                just had a brand new laser which we fitted to a mpc4503 and gave blank copies on black but ok on colour see my previouse post sc240-01 the fault was the new laser unit the very right mirror hidden under a cover had come out of position when we proded about with it the mirror slipped back in and copies were ok we didnt get any error code as the beam must of made the line detect sen
                • wyo19
                  • Nov 2012
                  • 51
                  One of the first parts I tried was a laser unit (gotta love parts machines) So I went over connectors one-by-one (fml) found the problem with the connector on the laser from the machine side was not seated all the way.... Thanks for all the replies....
                  • wyo19
                    • Nov 2012
                    • 51
                    Does it fail?
                    ACC and music failed no code except for the only one it thru SC-492 which was not listed in my 01/01/15 manual,but was listed on my 03/15 strange... Totally threw me off in my search for the fix.. Thanks again for your post,it helped me find the fix...
                    • wyo19
                      • Nov 2012
                      • 51
                      Just a thought... Will RICOH ever get rid of the laser and go with LED
                        • 37532
                        Why? I have had a lot more Contact Image Scanners (they use led technology) fail than laser units. I have seen a few B/W printers with LED. The higher the resolution that you want, the higher the cost of the LED array if it ever needs to be replaced.
                        • wyo19
                          • Nov 2012
                          • 51
                          Like I said just a thought, I've been a ricoh tech since the wheel was invented, now we've picked up the toshiba line and find the machine superior in some ways and dislike in others.
                          • Tonerbomb
                            • Feb 2005
                            • 2589
                            If you really want to go to LED, try hOKIDATA....................
                            Been there didn't like that, although the hoki's can do some awesome color output on some very off the chart media.................
                            • sharpmind
                              • Sep 2009
                              • 478
                              We had encountered the same problem which is there is no black image. We replaced new laser unit but same problem. Fortunately, we had pulled out same machine so we swap out the laser unit and it worked fine. We discovered that the new laser unit is faulty.
