MP c5503 Check Copying
  • iscott
    • Mar 2010
    • 344
    Any advice on how to copy checks on a MP C5503. Tried covering up the hologram and the yellow dots is the corner. Nothing but sky shots. tried reducing and enlarging. The only way I got it to work was from 81/2 x11 to legal which seems a little bit drastic.
    • 23010
    Re: MP c5503 Check Copying
    Try monochrome, combined with reduction or enlargement. =^..^=
    • duct tape
      • Jun 2009
      • 87
      Wgt the cousomer to copy several checks reduced down to one page it saves paper I tell them ,and gets around that problem.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        this is not a new thing with color copiers in the US. Here's what happened when I installed a new 02 color box in a local PD. They were copying money used for undercover buy's on their old machine, the new color box gave black pages. The Chief was in my face about it,told him about the reduce/ enlarge work around to no avail. Then I kindly informed him that it was required buy the US Treasury and the Secret Service. Never heard another thing about it from the Chief...............
        Customers don't read the sticker on the machine about "Prohibited copying materials" !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        Mystic Crystal Revelations
        • copier tech
          • 8192
          On early Canon machine's I found if you place the cheque further in the right of the glass it would work, copied a few notes too, I think it was the way the security worked it only scanned a certain area of the glass, might be worth a try.
            • 23010
            Originally posted by terramobil
            You can try to scan it to PDF and then print it out. With older models it worked.
            Doesn't work on Sharp. I had a call for scan errors. When I looked up the codes on the log it referred to " ... prohibited originals ...". We were able to repeat the errors with US currency. =^..^=
            • nos
              • Nov 2008
              • 78
              Try to reduce to 65%.
              That's what we do and it seems to work with all the different types of check security
              • Ottawatech
                • Feb 2015
                • 63
                Or enlarge 120% or more.
                Nothing works quite so well that I can't totally disable it by trying to make it a little better.
