Ricoh SP C440
  • Superbug
    • Aug 2025
    [Dead] Ricoh SP C440
    Hello , I installed a new SP C440,but when I turned on the machine , the screen is off , the initial process seems to start , but then remain only the fans running .
    I tried to install the firmware , but will not start the charging process .
    Any solution?
  • Debs1964
    • Oct 2010
    • 1693
    Re: Ricoh SP C440
    Any solution?
    There are 10 types of people in this world, those who understand binary maths and those who don't
    • keithxxiii
      Just a tech
      • Nov 2014
      • 469
      Re: Ricoh SP C440
      have you tried inspecting the fuse from the power supply?
      Aye! Cut the crap
      • Debs1964
        • Oct 2010
        • 1693
        Re: Ricoh SP C440
        No, but PSU is top of my list for parts to order, I was hoping someone else had had this problem and knew what part(s) were needed
        • anothertech
          • 1771
          Re: Ricoh SP C440
          Originally posted by Debs1964
          Was there ever a resolution to this problem as I have one doing exactly the same thing.
          There are lights on for the network, but cannot access WIM or ping device.
          Hello, by the way, it’s been a long time...
          Wow, I thought you went the way of Snake Pliskin! Good to see you back Debs.
          • Debs1964
            • Oct 2010
            • 1693
            Re: Ricoh SP C440
            Thank you, I don't come on here often as I seldom use a laptop, and the site is not good through a phone, but I do have lots of members as Facebook friends. I will try to be more active again, I promise
            • FrohnB
              • Jul 2017
              • 1919
              Re: Ricoh SP C440
              From the Ricoh Tech forum: "UPDATING, the problem here was not the PSU, it was the yellow toner RFID chip. Again."
              Symptom was "Stuck on please wait"/ couldn't load firmware/ in this case the fans and stuff did NOT turn on though, so might be different.
              Something to look at anyway.
              Omertà
              • guitar9199
                • Sep 2016
                • 1100
                Re: Ricoh SP C440
                It almost sounds to me like the controller is stalling. When in doubt, reseat all the connectors and boards and see if anything changes.
                • sandmanmac
                  • 3981
                  Re: Ricoh SP C440
                  haha.......and x2 on that one for sure!
                    • 37533
                    Re: Ricoh SP C440
                    As she said, she is on Facebook. I see posts daily from both Debs and gwaddle.
                    • sandmanmac
                      • 3981
                      Re: Ricoh SP C440
                      I understand Tim, but I cancelled my Facebook account nearly 10 years ago, and have no intention of opening another one, so from my standpoint, it's just really nice to see her here again for a change
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        Re: Ricoh SP C440
                        Welcome back Debs
                        • Debs1964
                          • Oct 2010
                          • 1693
                          Re: Ricoh SP C440
                          Thanks for the welcome backs. I've ordered a PSU, BCU and controller board, I'll let people know what it was when (if) I fix it
                          • Debs1964
                            • Oct 2010
                            • 1693
                            Re: Ricoh SP C440
                            OK, so, much to my surprise, it was the controller board. Obviously I tried the PSU and BCU first!!
                            But, once I got the screen back it showed an SC312, I checked, and rechecked all the connectors, even stripping it back down again to check the connections onto the HV board, just in case I had managed to dislodge a connector, I removed and reseated the K PCU a couple of times, but still SC312. Out of sheer desperation I rebooted the printer with the K PCU removed, then refitted it once it told me to reseat PCU, et voila...it only blooming worked. That was a fun 5 hours!!!
