MPC306 wont recognise network
  • barber782
    • Aug 2011
    • 286
    Hi everyone,
    I have a new MPC306 which i'm trying to install on a customers network. However it doesn't seem to pick up anything from the network when its plugged in.
    The network lights on machine are lit orange, and I cannot ping from or to the machine. Tried other cables etc. Iv also tried initialising network card with no luck.
    any help would be great.
  • francisco
    • Nov 2009
    • 168
    Re: MPC306 wont recognise network
    Originally posted by barber782
    Hi everyone,
    try to conect to your laptop
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Set the machine's IPv4 to Auto-obtain, and see if the device picks up an address. If not, the DHCP could be blocking unknown devices. If it picks one up, try pinging that address and use the hostname to print to.
      Most likely, the current IP address it is using is being used by another device. Hostnames are more reliable, unless you get a DHCP reservation in place.
      • Ricohguy
        • Sep 2012
        • 48
        You probably have 802.1x authentication turned to Active. Change to Inactive.
        • mikadonovan
          • May 2008
          • 2931
          It's in user tools >interface settings.
          NEVER ASSUME ANYTHING
          • barber782
            • Aug 2011
            • 286
            Thanks guys, we ended up returning the machine to our workshop. Typically the next day we had a look at it and it worked first time on our office network. I do find these machines to be quite temperamental. Had a few print control boards go bad on other machines as well.
            • Thirsty
              Hi
              Check the IEEE 802 1X Authentication settings under:
              User tools
              System settings
              Interface Settings
              Page 2
              IEEE 802 1x Authentication for ethernet should be INACTIVE
              Had this before ...caused me a brain freeze...
              Hope it helps
              Thirsty
              • sandmanmac
                • 3981
                Originally posted by Thirsty
                Hi
                User tools
                System settings
                Interface Settings
                Page 2
                Hope it helps
                Thirsty
                Good tip in some cases , except he said it worked at his shop in the post immediately above yours; Although it would be thoughtful if he'd return to update if it was resolved at client's office
                • StephenB
                  • Aug 2015
                  • 244
                  It could be that the customer network has their router turned OFF for DHCP devices ( banks and higher security clients do this ) You may need an assigned IP.
                  Always carry a laptop for exactly this.
                  • teebee1234
                    • Jul 2008
                    • 1670
                    In the future, save yourself a lot of trouble and confirm whether the issue is their network or the mfp (9 times out of 10 it will be the customers network). Use your laptop as a dhcp server and connect it directly to the mfp and see if it picks up an address from it. I've used this several times to prove to a customer that the problem was not with the mfp. I use opendhcp but there are other free apps available.
                    OPENDHCP
                    • copier tech
                      • 8172
                      OPENDHCP
                      Exactly as said above always check printing from your laptop you can then immediately diagnose a network related issue. These 306 even have onboard wifi so which is also usful for print tests from your smart phone etc
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        I have used some of these free DHCP utilities as well; they work great.
                        I have also been known to carry a small SOHO wired router with me. I think I found one in a computer store for about $20.
                        Note that I said wired, not wireless. I wouldn't want to be accused of broadcasting WiFi in a customer's office, especially one who is tight on security.
