Mpc4502 line when duplex thru adf
  • mrfuser
    • 1622
    Machine works great overall just when duplex thru adf we get a line on second side. Any thoughts?
  • jhalfhide
    • Apr 2015
    • 454
    Re: Mpc4502 line when duplex thru adf
    Got to be the inner slit glass. Single pass adf?
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      Is it a single pass doc feed?
      Incontinentia Buttocks
      • mrfuser
        • 1622
        Tech gave me wrong info. Does it off glass also
        • jhalfhide
          • Apr 2015
          • 454
          So if it does it on glass too, it's in the print engine (as to scan duplex from glass you're using the same lens/mirrors as the first side).
          • banginbishop
            grumpy old git
            • Oct 2007
            • 894
            To be clear on this does it do the line off the glass & doc feed AND via a print job? Or just off the glass/doc feeder?
            • jhalfhide
              • Apr 2015
              • 454
              Can't see how it can only be on the duplex side, through doc feed AND platen, without being on print too.
              • banginbishop
                grumpy old git
                • Oct 2007
                • 894
                Because im trying to get the correct information as its already changed from the original post. No point trying to give him help if it's the wrong fault.
                oh and it is possible you can have lines just on print jobs as it would be an engine issue not an optical fault.
                • jhalfhide
                  • Apr 2015
                  • 454
                  Don't be an Arse. Have a think about what I wrote. I said he can't have it on the duplex only side of platen glass copying and it NOT be an engine issue. Of course it can be print only and be an engine issue. [emoji23]
                  • logrady2331
                    • Feb 2011
                    • 301
                    No one has asked of the line is front to back, second side, about a quarter inch from the trail side (up and down)?
                    • mrfuser
                      • 1622
                      Yes that's it exactly
                      • banginbishop
                        grumpy old git
                        • Oct 2007
                        • 894
                        i actually can't be fuckin arsed to get into an argument with a clown who can't read his own statement correctly and tries to correct mine with a personal attack.
                        • mrfuser
                          • 1622
                          Can you help and not squabble kids?
                          • just a tech
                            • Jan 2007
                            • 332
                            Hi mrfuser... Several questions have been asked by others and it's still not 100% clear as to what problem you are actually having..
                            When you say, "Yes that's it exactly"... To which are you referring to as being "exactly" correct.?
                            -- does it do the line off the glass.?
                            -- does it do the line from the ADF.? (if so, is it only when duplexing.?)
                            -- does it do the line when printing Internal prints.?
                            -- is the line running from "front to back" or "lead to trail".?
                            -- and Etc....
                            As banginbishop pointed out earlier... Any help offered, won't be of any use to you unless we know exactly what's happening..
                            Thanks..
                            -JaT-
                            • mrfuser
                              • 1622
                              Only when duplex no matter what print or copy. Only second side and about a 1/4 inch in on trail edge lef
