MP C2051 not showing 'ready' or 'please wait'
  • MBZ6301
    • Aug 2016
    • 42
    Hi guys,
    I'm more than certain this will be some sort of HDD issue, but a customer currently has a 2051 that once turned on will not show Ready on the copy screen, or even please wait. I can't get into the SP mode, make copies or much of anything really. I can view the counter but cannot print it.
    I want to swap the hard drive, but just wondering if there is anything else obvious to try that I've not thought of?
    Cheers
  • LNorris
    • Sep 2008
    • 645
    Re: MP C2051 not showing 'ready' or 'please wait'
    disconnect hdd first to see if it will come up
    • HDSB
      Field Tech
      • Feb 2013
      • 64
      agreed, do above and switch on
      • mbolduc
        • Jun 2015
        • 53
        The machine can still function with the Hard drive unplugged. Just can't scan or duplex, real basic copying and printing. But at least you will know if the hard drive is the issue which it probably is.
        • MBZ6301
          • Aug 2016
          • 42
          Yeah it fired up straight away when unplugged, just need to head back and hope it fires up in order to back the address book up
          Thanks guys
          • AMEH
            please you may need to format the hard disk but make sure you back up your data.
            AMEH
            • bob marley
              • Jan 2012
              • 1339
              AMEH
              agree with u
              Live for yourself and you will live in vain. Live for others, and you will live again
              • diegura
                • Apr 2016
                • 5
                I had the same problem. Do this.
                Sin título.jpghttp://www.copytechnet.com/forums/ri...ease-wait.html
                • MBZ6301
                  • Aug 2016
                  • 42
                  AMEH
                  Luckily they only had one scan folder, didn't use the doc server, and no user codes or anything. Stuck another drive in, formatted and set the scan folder back up. Good to go
                  I couldn't have backed it up without use of trying to HDD on a PC I guess, turns out the HDD and data cable were both gone
                  • copier tech
                    • 8144
                    I had the same HDD issue but was able to back up the address book via the wim even tho the HDD had failed, mine was also thowing an SC8xx code
