MP C5501 I regularly get colored cubes
+ More Options
Posts
  • info@digitaalprint.be
    • Aug 2016
    • 33
    [Electrical] MP C5501 I regularly get colored cubes
    One MP C5501 I regularly get colored cubes ( CMYK) sometimes together , sometimes with dashes, but always in the middle of the page. I cleaned everything, including the laser. anyone have an idea?
    THX,
    Patrick
    One MP C5501 I regularly get colored cubes ( CMYK) sometimes together , sometimes with dashes, but always in the middle of the page. I cleaned everything, including the laser. anyone have an idea?One MP C5501 I regularly get colored cubes ( CMYK) sometimes together , sometimes with dashes, but always in the middle of the page. I cleaned everything, including the laser. anyone have an idea?
  • copier tech
    • 8225
    Re: MP C5501 I regularly get colored cubes
    Update ALL the firmware files then run full music, after check the results should show 11111111.
    Finally run ACC.
    This issue is related to itb patch timing
    • anothertech
      • 1771
      Sounds like maybe the ITB cleaning unit is not cleaning the belt properly.
        • 37631
        What you are getting are the process control patches. They are not being properly removed from the ITB by the cleaning unit.
          • Aug 2016
          • 33
          I already cleaned this. thanks for your answer.
          • anothertech
            • 1771
            Ok, time to replace it.
              • 37631
              You can actually do more damage trying to clean a cleaning unit. Since you say that the marks are in the middle and not on the front or back edges, the cleaning blade is warped either from trying to clean it or from using non Ricoh parts. Yes you can rebuild them. Yes Ricoh does sell parts to rebuild with, but when you add the cost of labor, it is less expensive to replace the entire unit. And using after market part will end up costing in the long run when they fail much sooner.
              • copier tech
                • 8225
                If the patches werent being cleaned off the itb i'd expect to see them smudged on the printout, if they are printed perfectly eg not cleaned at all see my post above.
                  • 37631
                  I have had the problem before and the patches are not smudged.
                  • techmann
                    • May 2016
                    • 41
                    Ive had the gears on the PTR roller go bad,(The 2nd transfer on the slide out drawer, not in the main transfer) and cause drive issues, I did see the patches on some of these, but the image was shifted also. Something to check...
                      • Aug 2016
                      • 33
                      This is my problem. (attachement)
                      • copier tech
                        • 8225
                        Your sample looks like a fuser issue, i'd rule out itb cleaning as the rest on the txt image is good
                          • Aug 2016
                          • 33
                          I have everything cleared and what should. Only the tranfer belt yet. The blocks come and go way back, erratic. Annex yet clear jpg
                          Patrick
                          • copier tech
                            • 8225
                            Did you see my post above about firmware & MUSIC etc?
                              • Aug 2016
                              • 33
                              I'll do it tomorrow and let you know.
                              Patrick
