MP C5501 I regularly get colored cubes
  • anothertech
    • 1762
    #16
    Re: MP C5501 I regularly get colored cubes
    Don't drive yourself crazy with this, just go ahead and replace the ITB cleaning unit and all will be well.
    • copier tech
      • 8131
      #17
      I agree, take a spare ITB & cleaning unit from a spare machine if you can
      • tnelson
        • Aug 2016
        • 21
        #18
        when you take the itb out flip it over and have a good look along the edge. we have had alot of them tear along the rear edge, then when it goes by it creates a bump mark. just food for thought.
        • info@digitaalprint.be
          • Aug 2016
          • 33
          #19
          Thanks everyone. I installed a new cleaning unit on the belt and everything was ok.
          I had the old blown out with an air compressor, but this is not sufficient.
          Patrick
            • 22999
            #20
            Patrick
            Congratulations. I didn't really think that compressed air would do anything to improve a warped or worn cleaning blade. =^..^=
              • Aug 2016
              • 33
              #21
              It was not really a problem that indicate the cleaning blade. When each printed four colors separately diced you think of something else
                • 37377
                #22
                When you understand the way that the process control system works, you immediately recognize the ID patches when you see them.
