Pro C5100 creasing paper
  • barber782
    • Aug 2011
    • 286
    Hi guys, having issues with a pro c 5100 machine, where the customer is getting intermittent creased paper, both A4 and A3. Being intermittent it makes it very difficult to pin point the source of the problem.
    Any help or advice would be appreciated.
    Sent from my GT-I9505 using Tapatalk
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Pro C5100 creasing paper
    When it is always creasing, you can interrupt the process at a certain time and look where the creasing starts...
    When it is creasing not al the time, it is a little more difficult, but it has something to do with uneven aligning (springs or worn out bushings) or a blockage in the path...
    I presume it creases with all the trays? Disassemble the finisher to count this out.
    • TonerMunkeh
      Professional Moron
      • 3865
      If the crease has a developed and fused image in it when you open it out, it's between transfer and fusing. If it doesn't, it's before transfer. Either one eliminated half the machine. Has the machine been set up correctly with that media in the paper library?
      Hit it.
      • MIKON
        • Jul 2015
        • 188
        Try changing the height of the transport bed.
        • barber782
          • Aug 2011
          • 286
          With regards to changing the height of the transport bed... I presume it tells you somewhere in manual how to raise and lower it?
          • MIKON
            • Jul 2015
            • 188
            Yes it's in the manual
            • barber782
              • Aug 2011
              • 286
              Hi, I couldn't find any adjustments for the transport bed in service manual. Any ideas?
              • MIKON
                • Jul 2015
                • 188
                Sorry i saw it on TSB 097.
                • copier tech
                  • 8192
                  What sort of millage is this machine on, fuser belt etc PM life?
