service log in for mpc401
  • digicor
    • 1152
    I had a call on a mpc401, did the call went to check the pm #'s and my service pass codes did not work IE: clm/107/c or clm/143/c/c can some tell me the new pass code, or is this machine screwy???
    • 8121
    Re: service log in for mpc401
    The 401 uses the newer SP log in, however this has been in use for a few years now!
    Y806182 C
      • 37068
      Were you using the RED stop key or the CLEAR key, usually either BLUE or GREY and the same size as the numeric keys. Factory service mode should still work if you use the correct key.
      • digicor
        • 1152
        ok im using the clear key not the stop key, and so now its Y? 806102 c ? what is y? you mean the 9 key? please explain, and im only into the 5502 and older, just now getting into the newer 401, 5503/4 ect
        thank you for your input
          • 37068
          The yellow clear modes key.
          • Iowatech
            Not a service manager
            • 3930
            Huh, so it's OK to post this sort of stuff out in the open now rather than using PMs?
            That seems kind of counterproductive. But that's just me.
            Oh, well.
              • 8121
              Oh, well.
              Well yes but this info has been all over this site for years now & lets face it when you're a newbe you don't have time to wait for a reply when you're standing at the MFD needing to get into SP mode!!!!!!
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                Oh, well.
                I found the answer in 30 seconds by putting "ricoh service mode new" into google. It's not exactly secret information so trying to hoard it won't help.
                • digicor
                  • 1152
                  thanks guy's ive been doing this since 1998, it changes from time to time,
                  i dint think to ask google, i guess thats a sign of the times too... har har
