C4502 fuser sleeve only?
  • mrfuser
    • 1621
    Is there a place to purchase just the sleeve and not the entire sleeve assembly?
    Seems such a waste to toss that entire assembly went all you need is a simple sleeve
  • COPIERMAN
    • Jun 2009
    • 559
    Re: C4502 fuser sleeve only?
    try precision roller off the web might have what you ar looking for
    • COPIERMAN
      • Jun 2009
      • 559
      here is web link Printer Toner Cartridges, Supplies and Parts at Precision Roller
      • mrfuser
        • 1621
        Yes I know about precision roller but I do not see just the sleeve itself without purchasing the entire sleeve assembly
        • Hoosierdaddy
          • Oct 2016
          • 181
          you can only get the upper fusing sleeve with the heat element included.
            • 37529
            Ricoh does not sell just the film sleeve because it is too easily damaged. Also, you do not want to try and disassemble the unit to change the film. I had to one time because a junior tech, who no longer works for us, ordered the 220 Volt version instead of the 160 volt one. The customer wanted the machine up. Had to swap the film from the new unit to the old unit. Disassembly wasn't bad. Reassembly without a fixture to hold everything in alignment was a nightmare.
            • tonnerboy
              • May 2011
              • 212
              When I read it I had a flashback!!! What a nightmare...
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                We have a 220v 02 or 03 series fusing sleeve around here because of someones whoopsie.
                • ruben
                  The New Guy
                  • Oct 2012
                  • 1203
                  If you are finding the sleeve not reaching it's life, make sure the firmware is up to date, and also replace the stripper plate.
                  It would be nice to have a seperate sleeve part, but remember, this is the new Ricoh.
                  • semi
                    • Sep 2008
                    • 195
                    https://www.surplustoner.com/product/RICOH.../D1444033/83907
                      • 37529
                      Your link is incomplete. I had to go to surplustoner.com and search the part number.
                      $127 and currently out of stock.
                      • sturmtrooper
                        Copier Combobulator
                        • May 2016
                        • 587
                        It is a huge waste, maybe Ricoh, who claims to be so eco friendly, thinks people will tear them down and recycle the metal. I don't know.
                        I hate sleeve fusers, feel like they are all made out of recycled but light cans.
                        • mbolduc
                          • Jun 2015
                          • 53
                          Looks like a good price, has anyone tried that vendor?
                          • apollo
                            • Mar 2008
                            • 191
                            Try Katun.com
                            they in U.K. And Usa
                            • Bantams
                              • Jun 2012
                              • 603
                              Tried it didn't rotate properly caused more problems than its worth not to mention the fact it takes up 1 hr more to fit the the assy
