MP C4503
  • CrapAimer
    • 296
    MP C4503
    Hi
    Got a MP C4503 with the code SC544-01 could someone point me in the right direction
    George
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MP C4503
    you most likely need a fuser sleeve and the special fuse that comes with it to reset the sc............
    Mystic Crystal Revelations
    • tnelson
      • Aug 2016
      • 21
      Re: MP C4503
      agreed, you've just got to love the 03 series!! NOT!! lol
      • Gumzum
        • Nov 2016
        • 2
        Re: MP C4503
        You can take one of the pressure sensors from a old bridge unit and make a reset button.
        That and 1.5 meter / 6feet wire so you can reatch the main power button. One of the old fuses to take the part of were the wire goes in to.
        1. Open the Fusing unit.
        2. Put the fuse reset button in the fusing unit. Do not press the sensor button!
        3. Put the Fusing unit back in to the MFP
        4. Do manual New unit reset (Fusing unit) under SP3xxx (Dont remember the exakt SP code)
        5. Shut off the MFP
        6. Push down the button when you start the MFP.
        7. Start the MFP. Extremely important! Do not hold it in for more than 5 second or you risk burning the mainboard.
        8. After that the SC554-01 will be gone.
        9. Take out the fuse reset button and assemble the fusing unit.
        • copier tech
          • 8192
          Re: MP C4503
          This reset method is simply not worth the risk! If the fuser sleeve is near PM life simply replace it & fuse that comes in the box.
            • 37556
            Re: MP C4503
            5. Shut off the MFP
            It might reset the code but if the cause of the code is not correct first, it will come back. SC 544 is a center thermopile overheat detection. When you turn the machine on, step 7, do so with the door open. Enter SP and monitor the fusing center temperature. With the door open, warm up not yet started, it should be about 27 degrees C and not rising. If it is at or above normal operating temperature, the thermopile is bad. If it is rising like it would with the door closed, the triac is shorted, replace the power supply.
            • apollo
              • Mar 2008
              • 191
              Re: MP C4503
              Than reset sp5810- 2
              • imaginemoko
                unTrusted Tech
                • Jan 2008
                • 289
                Re: MP C4503
                try first the SP 5810-1, else replace sleeve with fuse the sp 5810-2, rest also at SP 7622-** the fuser sleeve
                fix the customer first then fix the machine... its simple and makes life more easy.
                • CrapAimer
                  • 296
                  Re: MP C4503
                  Many thanks for the advice, i have ordered a new sleeve and will get it fitted
                  George
