Ricoh mp c6502 magenta marks/line
  • apollo
    • Mar 2008
    • 182
    [CQ] Ricoh mp c6502 magenta marks/line
    Hi and thank in advance for any input
    Getting like scrap marks on magenta only as per pic.
    Drum, Dev , cleaning unit all checked and cleaned
    Itb assbly checked.
    Swapped the whole drum unit with yellow by removing Dev unit and swapping still same issue
    Magenta Dev has nice uniform later Dev on mag roller.
    I checked inside copier where pcdu goes nothing obvious
    All laser cleaned.
    Any one had similar fault, any input would be appreciated
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    Re: Ricoh mp c6502 magenta marks/line
    its looks like coming from under the development unit.
    fix the customer first then fix the machine... its simple and makes life more easy.
    • apollo
      • Mar 2008
      • 182
      Checked Dev unit
      Going to customer again today will look further
      • TonerMunkeh
        Professional Moron
        • 3865
        From the way that's blown out, looks like something is impeding the laser beam. Check the magenta laser aperture for debris.
        Hit it.
        • apollo
          • Mar 2008
          • 182
          Was thinking same laser related
          will be going in morning
          will post updated
          thanks
          • DougD
            2020 Retired
            • Sep 2016
            • 76
            The way the magenta toner is being dragged into the yellow leads me to think the problem is with the magenta image transfer roller not contacting the underside of the belt properly.
            If there is crud built up on the roller. the belt wouldn't be smooth right at the point where the image is transferred from the drum.
            Wrinkles in the belt would account for the void streaks and the jitter.
            This is only my humble opinion since I don't work on this model.
            • ESTANISLAOWENENTON
              I do not write or speak very well in englishBut I would say that it is the unit of magenta development, it is deformed or it is dirty in the center.I say so in several occasions I have seen
                • 37376
                • apollo
                  • Mar 2008
                  • 182
                  Hi
                  Just and update the the fault
                  The issue was cause by mylar underneath cyan drum unit, causing magenta cq fault.
                  thanks
