Re: MP 4001 SC995 ERROR
i agree, betting its not the correct controller. if the part# isn't D092-5724 you've got the wrong one! nothing you do will change the 995 code.
MP 4001 SC995 ERROR
SC995 means the controller is not the right one. This series is a little complicated on which boards fit what, but I've seen it a ton. Wrong controller.Leave a comment:
I do appreciate any help....The only number I can find on the original board is D0925103B & the same number on replacement is 0855300J Every component and chip on both boards is identicalLeave a comment:
Now you want to resort to name calling? I'm fine that this forum is not for me....If you don't want to help me that's fine too.
But why do you need to call me a snowflake? How adult of you.Leave a comment:
RAM from old board should be moved to the new boardLeave a comment:
What a little snowflake, maybe you need some how chocolate...hmmmmmm?Leave a comment:
Are you sure you have the right Controller Board? D0925724 is for the MP 4001 and D0925714 is for the MP 5001. The boards are not interchangeable and eBay is no guarantee that you got the right PCB. SC995 will not clear if it is the wrong board.Leave a comment:
OK point taken, I'll go elsewhere for answers. Thanks for nothing.Leave a comment:
**Update... I found the info on how to enter the service menu, the serial number did need changed to match the number of the machine.
I changed it and re-formatted the HDD, but the SC995 error is still present.Leave a comment:
MP4001 is not so old!!!
A certified tech will solve your serial number problemLeave a comment:
We are located in a rural area, so certified techs are not readily available. This is an old machine no longer covered by a service contract. We would like to
save it from the landfill if possible. I don't have access to the service manual for this machine, and have had little luck finding it online.Leave a comment:
If you read thru the service manual it will explain how to get into service mode
and also the procedure you must follow when replacing boards
i advise you to get help from a qualified techLeave a comment:
