Can anyone help me fix this error code Sc982 to my xerox machine ricoh 1015. We just only lift up the machine and change its place and when i turn it on it plug that ettor code. Can you please help me? And to those who encounter it and they solve it please help me.....
Problem Sc982 code
Re: Problem Sc982 code
It would be much easier to help if you'd post the correct error code because SC982 doesn't exist in any documentation i have
And posting it 3 times, in 2 different forums is also very unnecessary, and annoying -
Sir the error plug in the screen is SC 982... I cant make a copy because at the time i on the xerox machine SC 982 plug at the screen...Comment
Maybe you have to look in your Xerox service manual. After all, it is a Xerox isn't it?Comment
Well good luck to you, because as I said, that code doesn't exist on your machine, or any other RICOH model as far as I knowComment
SC 982 is most likely a localization error. Location set in SP mode does not match region for which the machine was originally manufactured.Comment
Every day of life is a learning process... Just make sure you are open in all aspects of comments.Comment
Obvious you are an end user. A tech would know that a Ricoh 1015 is not a Xerox machine, it is a Ricoh. Xerox is a registered brand name for equipment manufactured by or for Xerox.
Sent from Huawei P9 LiteLast edited by Service@PRT; 12-06-2016, 10:30 AM.
Start from the beginning, have you eveer seen the "copier" working, EG have you seen it come to ready & do a copy/print?
Have you tried to clear the main counter by swapping boards or NVRam? Be honest.Let us eat, drink, and be merry, because tomorrow we may die!
โComment
