Problem Sc982 code
  • 3jxerox
    • Dec 2016
    • 5
    Problem Sc982 code
    Can anyone help me fix this error code Sc982 to my xerox machine ricoh 1015. We just only lift up the machine and change its place and when i turn it on it plug that ettor code. Can you please help me? And to those who encounter it and they solve it please help me.....
  • sandmanmac
    • 3979
    Re: Problem Sc982 code
    It would be much easier to help if you'd post the correct error code because SC982 doesn't exist in any documentation i have
    And posting it 3 times, in 2 different forums is also very unnecessary, and annoying
    • 3jxerox
      • Dec 2016
      • 5
      Sir the error plug in the screen is SC 982... I cant make a copy because at the time i on the xerox machine SC 982 plug at the screen...
      • anothertech
        • 1760
        Maybe you have to look in your Xerox service manual. After all, it is a Xerox isn't it?
        • sandmanmac
          • 3979
          Well good luck to you, because as I said, that code doesn't exist on your machine, or any other RICOH model as far as I know
            • 37345
            Obvious you are an end user. A tech would know that a Ricoh 1015 is not a Xerox machine, it is a Ricoh. Xerox is a registered brand name for equipment manufactured by or for Xerox.
            SC 982 is most likely a localization error. Location set in SP mode does not match region for which the machine was originally manufactured.
            • Service@PRT
              • Oct 2016
              • 181
              check this thread... http://www.copytechnet.com/forums/ri...-sc-982-a.html
              Every day of life is a learning process...
              Just make sure you are open in all aspects of comments.
              • Service@PRT
                • Oct 2016
                • 181
                Slimslob.. from what i can see.. he is from philippines.. as it says location manila. Photocopier in the philippines called xerox by nature.. so its not really a brand xerox hes talking about. Its ricoh... pardon his knowledge on this matter... in the philippines when you want to photocopy something.. they will tell you xerox this from page 3 to 45... so naturally photocopier is called xerox there... instead of photocopy this.. they tell you xerox this.. just look at those signs ONLY IN THE PHILIPPINES
                Sent from Huawei P9 Lite
                  • 8132
                  Start from the beginning, have you eveer seen the "copier" working, EG have you seen it come to ready & do a copy/print?
                  Have you tried to clear the main counter by swapping boards or NVRam? Be honest.
