Mpc5502 blurry when printing
  • mrfuser
    • 1622
    Some reason when client prints most of the time it is blurry. Looks like color registration is off. Internal prints and copies are fine. Any ideas?
  • qbert69
    • Mar 2013
    • 1152
    Re: Mpc5502 blurry when printing
    Is one color shifted off to the side in the opposite trailing direction of paper travel?
    I have seen a slipping magnetic clutch for a particular color cause this issue--that is, if it has a main motor and a clutch which engages that drum unit.
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • mrfuser
      • 1622
      Thanks. Only happens when print from pc as I stated.
      • mikadonovan
        • May 2008
        • 2931
        Could be a print driver issue. You need to post an example.
        NEVER ASSUME ANYTHING
        • mrfuser
          • 1622
          Example
          • geardriven
            • May 2008
            • 32
            Hi
            I would start with deleting the print drivers and reload them. also try printing from another computer if that dosn`t change anything try updating the firmware and if still doing it then my guess would be the print card.
            • billm
              • Jun 2012
              • 50
              try resetting sp 5801 8 printer ap had something similar when printing pictures
              • andy227
                • Jan 2013
                • 219
                Forced line adjustment sp2-111. Had one the other day exactly the same. You say 'internal' prints are ok, but try the obvious first, do the forced line adjustment and go from there.
                  • 37560
                  Example
                  [ATTACH=CONFIG]35533[/ATTACH]
                  The blurred text appears to be printed as composite black. If the line position is off the individual colors of the composite will not align. Before doing a forced line position adjustments, properly clean the ID sensor or the line position might fail. I have also had cleaning the sensor pull the alignment back in without forced adjustment. If it adjusts but a day or two later goes out again, replace the ITB unit, not just the belt. Ricoh had some problems with the belt slipping on the 02s and causing the line position to vary.
                  • mrfuser
                    • 1622
                    Something wrong with itb. Swapped with another and works fine. Now to figure out what is wrong!
                    • Zeldaman
                      • Mar 2011
                      • 946
                        • 37560
                        Ricoh did have reported problems with the ITB belt slipping on the unit. Only solution was to replace the entire ITB unit.
                        • Imprestik
                          • Aug 2012
                          • 297
                          I use the SPC830DN transfer unit as it extremely cheap and does the same job.....
                          If your stuck just get the transfer unit from the SPC820DN then, exactly the same thing except the cleaning station has 2 blades instead of 1
                          Again a lot cheaper and easier than trying to diagnose a issue with the transfer unit its self....
