MPC6502 sc670 and sc819
  • MitchD
    • Oct 2012
    • 164
    Re: MPC6502 sc670 and sc819
    It was on the fuser itself
    Originally posted by fireater
    was this pinch in the wiring on the fuser or at the back where the fuser plugs in to the copier
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
    • fireater
      Repair God? not quite
      • Apr 2006
      • 253
      power supply.. not sure which one yet as I swapped out all three from a used machine .. will post details once we figure it out
      I fix copiers ...Well Sorta
      • fireater
        • Apr 2006
        • 253
        AC power supply ..fixed it
        • digicor
          • 1153
          #19
          i have the same problem , the drawer open fuser pinched wire did not get it to come to ready, which a/c board is it? you replaced to fix it?
          • fireater
            • Apr 2006
            • 253
            #20
            there are two dc power supplies and one ac. not much on the board just a few small black relays
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              #21
              Originally posted by oyedokunmj
              How to change language of HP color LaserJet cm 6030mfp to English language
              Sent from my Infinix X510 using Tapatalk
              WTF does this have to do with this thread?????????????
              Mystic Crystal Revelations
                • 37491
                #22
                Iowatech told him where to go.
                • digicor
                  • 1153
                  #23
                  got it ok thanks
                  • yknot
                    • Oct 2010
                    • 5
                    #24
                    Originally posted by gkalman2004
                    For 670 if you have mailbox you must update the firmware also (mailbox-ontario-d)
                    search in the attachement for 670 you will find it
                    [ATTACH]35598[/ATTACH]
                    Sc670 caused by worn bypass harness also takes down paper feed pcb replace both old firm ware also sc670
                    • digicor
                      • 1153
                      #25
                      Believe this or not!
                      they send the wrong power cable with the machine!
                      its the same on the machine end but different on the plug end, what a bunch of cow manure,
                      we were plugging it into a dedicated 120 and its 240, but the plug that came with the machine was a dedicated 120 plug cord, so what are we to think?
                      come to find out its the power cord.... just an FYI these machines were new to us and the Power cord that comes with the machine you would think is the one for the machine!!!!!!
                      • levantin
                        • Aug 2019
                        • 26
                        #26
                        so replaced op panel and usb cable again recommended by Ricoh tech support. turned on machine and waited ... 4 minutes later SC670-00. does Ricoh have a dart board repair method when you call them for help? I can guess at shit too!
                        I'm gonna do nvram and system memory next.
                        Can you give me a way to resolve this error?
                        • davel
                          • Oct 2011
                          • 1104
                          #27
                          • guitar9199
                            • Sep 2016
                            • 1100
                            #28
                            If you read through the threat, you'll see that in this case the tech replaced the power supply.
