Ricoh mp 4000
  • mrfuser
    • 1622
    Ricoh mp 4000
    anyone have install instructions for the fax system on the mp4000? Seems plug and play but not working
  • sandmanmac
    • 3983
    Re: Ricoh mp 4000
    It is plug and play (assuming you have the right one). However, the issue is most liekly that the MBU is not tightly 'plugged' to FCU so it doesn't load, or shows SC672.
    Btw...MP4000/ 5000 Manual is among the easiest to find online (free) if you could be bothered to look
    • Polarbear
      • Feb 2012
      • 1070
      Re: Ricoh mp 4000
      What do you mean "not working"?
      Is there an error message of a code?
      Is does the fax simply not pitch up in the options?
      Press the GREEN button!!
      • HDSB
        Field Tech
        • Feb 2013
        • 64
        Re: Ricoh mp 4000
        set the jumper to on?
        • mrfuser
          • 1622
          Re: Ricoh mp 4000
          What jumper? It does not show up at all. We did see it briefly flash on in utility mode but then nothing.
          • Elmo
            • Feb 2010
            • 541
            Re: Ricoh mp 4000
            as sandmanmac said the mbu board needs pushed into position
            I Used To Live To Fix Things Now i Fix Things To Live
            • mrfuser
              • 1622
              Re: Ricoh mp 4000
              Thanks guys. That is what I thought, I removed and reinstalled the board multiple times. No good still.
              • anothertech
                • 1771
                Re: Ricoh mp 4000
                What's the product code of the fax unit, could it be the wrong one for the machine?
                Maybe incompatible levels firmware between the mp4000 and the fax board?
                • mrfuser
                  • 1622
                  Re: Ricoh mp 4000
                  D3465132a says on the board.
                  Cant seem to upload pics from iPhone anymore.
                    • 37556
                    Re: Ricoh mp 4000
                    That is the correct FCU board, but what MBU board is mounted on it? The MBU is where the FAX program is loaded. If it missing, incorrect or defective the FAX function will not be shown.
                    • mrfuser
                      • 1622
                      Re: Ricoh mp 4000
                      D3465180E
                        • 37556
                        Re: Ricoh mp 4000
                        D3465180E
                        OK. Thats the correct one for the ML4000"5000.
                        • anothertech
                          • 1771
                          Re: Ricoh mp 4000
                          The jumper on the fax board, move it from off to on.
                          • Xcelsior
                            Ex-Tech
                            • Jan 2017
                            • 24
                            Re: Ricoh mp 4000
                            As mentioned, make sure the small blue jumper on the fax board is set to ON. Even on machines with the board installed at the warehouse the jumper can be forgotten and you just have to change it.
                            Just slide the unit out and you should be able to see the jumper towards the bottom. It will have "ON" "OFF" in very fine print on either side of a 3-pin jumper.
                            Previous Ricoh Field Service Tech II - November 2017.
                            • mrfuser
                              • 1622
                              Re: Ricoh mp 4000
                              I had to install and uninstall the board multiple times and during this I was getting random sc672 errors. Finally on one of the reinstalls it just started working out of the blue ! Yeah Ricoh
