Ricoh MPC2051 Memory Clear?
  • mrfuser
    • 1622
    Anyone have a clear understanding of doing a memory clear to remove any user data and logs?
    Thanks all! yer da best
    • 8179
    Re: Ricoh MPC2051 Memory Clear?
    Yes this will reset the machine back to factory default.
    Only use if absolutely necessary & if you have the birth certificate.
    • mrfuser
      • 1622
      Um, ok. Not what I asked though. There are many sp actions regarding memory clear and I was just wanting to clear user address books, logs and such.
      • jonhiker
        • 661
        Look for UCS clear. That will clear the user data and not the machine settings. It is in the 5xxxx like the memory clear. Can't remember exactly where...
          • 37538
          SP 5846-050 Initialize All Addr Book
          Clears all directory information managed by UCS, including all user codes.
          • Moza
            • 232
            if you need to clear all data as well as above I would clear copier/printer/scanner Application in SP 5801 and format HDD
