Mp c4503 Please Wait
  • Timmytronic
    • Oct 2010
    • 249
    Hi. I have a Mp c4503 saying please wait with the blue background graphic that Ricoh use. I have changed the control panel as I had a spare one as when the machine turns on it warm up or the fuser does anyway. It does not beep tho and if you open or shut a door it makes a few noises. But the new control panel still says Please Wait with the blue back ground.
    Has as anyone has this or know what it is? Next step was Harddrives but I don't have any spares so will buy them in but thought I would check before I do. The machine won't let me on the engineer mode as screen is locked on this please wait all the time like when you first start the machine on them all. I was hoping to initialise the hard drives inside if so.
    Any help would be welcome.
    Hope you all are having a lovely summer.
    Tim.
  • COPIERMAN
    • Jun 2009
    • 559
    Re: Mp c4503 Please Wait
    In the past most would say unplug hard drive. copier should come up but those features that need it wont work.
    • copier tech
      • 8172
      Before replacing ANY parts the first procedure should always be to update ALL firmware files.
      Have you tried this yet?
      • guitar9199
        • Sep 2016
        • 1100
        I have a similar one in our warehouse. We got it working by replacing the Main Controller, and then re-flashing the firmware. Before we replaced the controller, the machine wouldn't even boot into "Firmware Update" mode.... The one we had was using the Smart Panel V1, so we had to swap it with the standard op panel, update the firmware, and then RE_install the smart panel.
        ....Have to say, I'm not a fan of SOP V1!! I like Version 2 much more!
        ....long story made longer...Main controller failed a 2nd time. I'm suspecting a power surge/lightning strike.
          • 37532
          In case you have an non displayed SC 672-11 or -12 it might be a controller startup error. Possibly a loss of communication between the controller and the display panel. Possible quick fix is to unplug and then reconnect the USB cable between them. See the attached bulletin for more information.
          rfg067672.pdf
          • Timmytronic
            • Oct 2010
            • 249
            Thanks everyone for coming back. Will have a check on Monday and let you know what the outcome was. Will start with slims idea first as easiest and Slim you always seek to hit the nail on the head. Have a fun weekend folk.
            • semi
              • Sep 2008
              • 195
              Pull out all the paper trays & reboot,theres a rtb for this,should work fine.
              • anothertech
                • 1771
                What tech pub is that? Can you post it please?
                • semi
                  • Sep 2008
                  • 195
                  TS Bulletin 090.pdf
                    • 37532
                    [ATTACH=CONFIG]36713[/ATTACH]
                    A little more recent information in a Ricoh-USA bulletin 060. Includes actual tray problems that can be the cause plus the firmware that is susceptible.
                    060-rfg076218.pdf
                    • fran780
                      • Nov 2017
                      • 7
                      thank you very much for your help!!
