MPC 3002 SC 101
  • gestetner tech
    • Nov 2009
    • 45
    MPC 3002 SC 101
    This is a mysteri.
    i have checked the mirrors and white plate. clean. New explamp, PCB SIO PCB Led-DB SBU latest FW and still it kicks out sc 101
    Any hints in this problem
    Regards Lars
  • HitMan
    • Aug 2015
    • 170
    Is the df slit glass in the correct orientation? Black strip to left side. Does the lamp light up?
    • Polarbear
      • Feb 2012
      • 1070
      Re: MPC 3002 SC 101
      Originally posted by gestetner tech
      This is a mysteri.
      Regards Lars
      Silly question I know; but do the mirrors move when it does white/black level detection?
      Press the GREEN button!!
      • gestetner tech
        • Nov 2009
        • 45
        Re: MPC 3002 SC 101
        scaning could work for 50 double side or single sided for a whole day then suddenly it kicks out sc101
        • HitMan
          • Aug 2015
          • 170
          Sounds like the slit glass I had the same issue would work fine then randomly throw up sc10q when using the df. Does the df have a CIS?
          • gestetner tech
            • Nov 2009
            • 45
            Re: MPC 3002 SC 101
            Hi Hitman
            The slitglas are in the right posistion
            What was the problem with your slitglas?
            • Mark Bbb
              • Jun 2012
              • 1662
              Re: MPC 3002 SC 101
              I have had this once on a mp4000. The solution was transporting the building up heat...
              Machine was standing in a not good enough ventilated room, so no turn over off air => heat building up round mfp.
              I have removed the metal plates above the print-boards so more warm air could escape; solved!
              It also can be a problem with the fusing unit, it becomes to hot due to ???
              Also, customers are scanning a very lot these days, so that can also be a reason.
              • Mark Bbb
                • Jun 2012
                • 1662
                Re: MPC 3002 SC 101
                I have removed the metal plates above the print-boards in the scanner cavity
                • gestetner tech
                  • Nov 2009
                  • 45
                  Re: MPC 3002 SC 101
                  Hi well the mc has been on same location for 3 years with a lot of scanning and suddenly started to kick out sc 101 today a changed IPU board still the same problem.
                  Now i am out of ideas :-(
                  Lars
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Re: MPC 3002 SC 101
                    Lars
                    Well, that was also the case in my situation with sc101 on a mp4000!
                    Is the machine in a ventilated place and is the gap between wall and machine big enough?
                    Is the fusing unit old?
                    • copier tech
                      • 8172
                      Re: MPC 3002 SC 101
                      How about firmware, have you tried updating them all (not just scanner) that should be the first thing to be done before replacing hardware.
                      • gestetner tech
                        • Nov 2009
                        • 45
                        Re: MPC 3002 SC 101
                        Of course first thing i did!
                        • Polo-022
                          • Sep 2007
                          • 486
                          Re: MPC 3002 SC 101
                          Exposure lamp stabilizer. P.N: ΑΖ50-0070
                          Did you replace it with a new one?
                          • gestetner tech
                            • Nov 2009
                            • 45
                            Re: MPC 3002 SC 101
                            To mu knowledge there are no lampstabilizer The part P:N are not listed anywhere
                            Check my first post and you will se what have been replaced without any succes.
                            • gestetner tech
                              • Nov 2009
                              • 45
                              Re: MPC 3002 SC 101
                              Hi
                              how do you mean that the fuser could affect the sc101?
                              I know it said time to change fuser but that was 60k before the PM so i just reset the counter
                              But i realy dont know how the fuser could be involved.
                              Lars
