MP2851 can't scan to new Windows 10 computer, others still work
  • copyaction
    • Oct 2007
    • 991
    Customer got 1 new windows 10 computer today, tried to set up scan to folder and it times out with "Connection with the destination has failed"
    Previously updated firmware and 2 other windows 10 machines still scan fine.
    Tried everything in the recent "RICOH MPC4502 Can't scan to folder" thread
    Error log shows - SMBC: failed to connect (03201:0x2100002) ERR:
    Made sure SMB1.0 is turned on in windows features.
    File sharing is on. Folder is shared properly read/write. Also turned off Windows Firewall.
    Tried "ip address" and "computer name" in Path
    Prints fine from this computer and I can pull up the WIM as well.
    There must be a setting I am missing?
    • 37556
    Re: MP2851 can't scan to new Windows 10 computer, others still work
    Is the new computer part of the same workgroup as the other computers? Is NetBIOS over TCP/IP disabled on the computer as this will prevent host name resolution and Microsoft Update from a little over a year ago does not play nice with scan to IP address, thinks the MFP is a spam source and blocks it. This is especially true on a domain or with multiple subnets.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Failing all that...is it possible to setup a shared scan location on the customer's network?
      If it's confidential scanning you could setup a sub folder for that particular user maybe?
      • copier tech
        • 8192
        When I get this issue I start by plugging in my laptop directly to the MFP with a cross over cable, then try a SMB scan to your pc as you will 100% know your Win logon is correct ;O)
        If that fails you know the issue is with the copier, if it works then look at the customers PC/network
        • tjvincent
          • 280
          Did you try browsing to the PC from the machine ?
            • 37556
            You obviously did not read his full post. If you had you would have realized that the 2851 is already scanning to 2 other computers. No need to test it with his laptop.
            • gkalman2004
              • 157
              Check with firewall and antivirus disabled.
              Also check if the share is accessible from other pc.
              • copyaction
                • Oct 2007
                • 991
                Thanks slimslob I will try Netbios today.
                No I could not browse to the pc from the copier.
                Yes their 2 other Windows 10 computers are still scanning fine.
                yes I tried it with firewall turned off.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 471
                  I received a call from one of the ITs, saying that their windows 10 was working fine hours before he had installed the windows updates. I asked him to uninstall those updates and scan to folder started working fine again. I just cant find my notes on which KB was it. sorry my bad
                  Aye! Cut the crap
                  • aktasson
                    • Feb 2017
                    • 201
                    You have in Windows the possiblilty to check under SMBServer entrys (Computer Management Console, Applications, Microsoft, WIndows) for security or connectivity loggs.
                    If no entry exists, then you have probably a problem with the firewall/router/switch.
                    • copyaction
                      • Oct 2007
                      • 991
                      the NetBIOS over TCP/IP fixed it. Thanks!
                      • jimtanis
                        • Oct 2010
                        • 6
                        Do you have latest firmware?
                        I have similar problem with older MPC3300
                        Good luck!
                        • anothertech
                          • 1771
                          Good call on this. I learned from it.
