Mpc4502 transfer separation clips breaking
  • mrfuser
    • 1621
    Have a client that just had both clips that hold transfer roller unit in place break. Any idea why this would happen?
    also anyone have a part number for them?
  • ESTANISLAOWENENTON
    my friend
    criminal hands
    so simple
    in a site a girl of 86 pounds and 4.5 feet destroyed those units on several occasions
    and ? nobody was
    • mrfuser
      • 1621
      Re: Mpc4502 transfer separation clips breaking
      Nope, these are the grey arms that hold the entire assembly onto the right door at the to of the assembly
      • sandmanmac
        • 3981
        You work on tons of Ricohs, and know EXACTLY what you need . Why don't you look it up?
        You're always asking for P/N's.
        Invest in a manual or 2!
        • mrfuser
          • 1621
          Wow, just wow. Thanks sandman for the Prozac rant 😂
          • eddy out
            • Oct 2016
            • 359
            in a pinch I have used a molded paperclip to secure the ptr in place with no problems. D1446316
              • 37529
              I had a machine where that was the only solution short of replacing the entire assembly. If I ordered the actual clip and replaced it, as soon as you closed the door and opened it, the new clip was broken.
              • davel
                • Oct 2011
                • 1107
                The clip will break if the tops of the 2 black guides that locate the PTR assy are broken. ( just under fuser)
                • Bantams
                  • Jun 2012
                  • 603
                  Take them off if they are broken its usually the front one and it will work fine without
                  • fshead
                    • 2376
                    bravo..
                    and maybe say thanks once in a while
                    • copier tech
                      • 8169
                      Here's the parts manual.
                      But the part you are looking for is:
                      Holder D1446316
                      & also as slim said also order these two also.
                      Guide Position Front D1446318
                      Guide Position Rear D1446319
                      https://mega.nz/#!cEU3UCgD!b2jCs-EXmvd592yINyp0hrH1egOXFXqLdI0ymt5MhQ0
