MPC4502 SC544 reset procedure?
  • mrfuser
    • 1622
    Ok, fuser sleeve is toast. Rebuilt and added the new fuse. I believe we need to do an SP5810-002 to reset correct? I seem to remember you had to have a door open or something. Is that correct? Or do we just install the new fuser with the error in place and run the SP mode? Sorry, I have looked at all the bulletins and such and it is not too clear.
    Thanks!
  • copier tech
    • 8174
    Re: MPC4502 SC544 reset procedure?
    Thats correct, replace the sleeve & fuse run SP5810-02 with all covers closed, power cycle done.
    • StephenB
      • Aug 2015
      • 244
      Thanks!
      Little off subject, but I found a great thread here from 2-15-2013 on a MP C 3502, SC 554. Someone came up with a GREAT idea of using the connector lead from an old fuse, then splicing a longer lead on with a momentary switch on the end.
      ( use this procedure when transfering a fuser from another machine )
      Attach your switch lead to the fuser,where the fuse goes, close everything up, access SP 5810-002, press switch closed ( this mimics the fuse). Then press execute. Release switch after a half second. Reset ! Good for a pinch until a rebuild or new fuser comes in.
      • fshead
        • 2376
        i built my "reset jig"..pretty easy to do
