MP 2550 Mystery Jam
  • rthonpm
    • Aug 2007
    • 2859
    MP 2550 Mystery Jam
    I've got a customer with a fairly new 2550 that's giving them a persistent lag jam at the junction gate sensor (code 065) after the machine runs for a little while.
    I took out the fuser and inverter unit and everything looked good, but it seems like it comes back with a vengeance every few weeks. By the time I'm able to get there the machine is fine.
    I've seen a couple of strange jams on this model, but nothing that can account for this.
    Any ideas would be appreciated...
  • E Winter
    I have no specifiv idea but does this happen during a duplex job? Does the paper "crash" or stop inside the machine without any damage?
    • Star
      Ricoh Tech
      • 127
      Firmware up to snuff?
      • rthonpm
        • Aug 2007
        • 2859
        Firmware is the latest and greatest. I have yet to see the machine jam myself, even running over 200+ pages at a time for testing... I will be starting my day there when they next run their big job.
        If I find anything I will share properly...
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          check the discharge grid (does this machine have one?) if the power pack fails for the discharge grid you will get jams like you mention on duplex jobs, as after a while theres no discharge for the paper and static charge bulids up, this can cause odd jams like this. (especially on duplex)
          Networking skills are advantageous but use of a 3m vacuum cleaner is essential
          • rthonpm
            • Aug 2007
            • 2859
            Thanks Leo...
            I think I've narrowed down to the sep pad for tray one. Having finally seen the machine jam, it seems that it chain feeds: there was a page past the drum with an inverter jam but there is no image on the paper. The pad is one of the plastic type as opposed to the cork pads that just seem to hold up better.
            • rthonpm
              • Aug 2007
              • 2859
              I finally got an answer on this one: it's a firmware error with the resolution still in production. It is supposed to be released soon....
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                I think I could have a similar issue with a MP2550 30k on the clock.
                Non feed jams being logged for Tray 1, A4 LEF and jam code 57 (reg late) shown as the latest plotter jams.
                Customer says they remove two sheets from the reg area every time it happens.
                But sure enough when I'm onsite I cannot recreate the problem, it works fine for hundreds of copies.
                Strange one.
                • rthonpm
                  • Aug 2007
                  • 2859
                  Cipher, that sounds a lot like my issue as well: double sheet feeding and such. I have yet to see firmware for this issue come out and I have one customer still having repeated issues with this jam. Maybe the speed is too great for a non-FFR feed system?
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Watch these buggers, they're a good one for throwing up really wierd jams.
                    A good one I've seen is where the side fence position sensor gets knocked out of place by customers pushing the tray back in with a little too much force. It'll present faults such as the machine detecting A5LEF with A4LEF in the tray, A4LEF with A4SEF in the tray. This is while the machine is on Auto Detect. When the tray is set to a certain paper type in User Tools, it will just continually jam out of the tray.
                    Hit it.
                    • Cipher
                      • May 2006
                      • 1309
                      I've reset the jam counters and asked the customer just to use tray 2 for their A4 LEF for a few days.
                      I just want to see if they get the same issues using a different tray source.
                      A non-feed would suggest the bottom plate pressure may not always be sufficent or the feed clutch is failing to engage intermittenly.
                      But as I cannot recreate the problem it's not easy to get a picture of what is actually happening.
                      If I make any progress on this one I'll be sure to let you know.
                      • iMind
                        Vacuum Cleaning Expert
                        • Mar 2008
                        • 1116
                        • KopyKat
                          Nurse Ratched of Repair
                          • Nov 2008
                          • 365
                          Had a non-feed problem in tray 1. Trial and error with the settings in the attached file (SP 1908) for the pressure plate adjustment and it did the trick for me.
                          Might be worth a shot. I highlighted the SP Modes.
                          sigpic
                          Relax! This firmware injection won't hurt...but it will take 45 minutes.
                          • largo
                            • 30
                            yep, like tonermunkeh says:
                            at the rear of the machine the sensor pops out of the little chasis
                            then if your machine is set in usermode on auto detect paper,
                            than the machine gives an other paper format and also sometimes add paper when there is still some paper in the tray left
                            I would check first this option because i had a lot of this problem
                            greetz
                            greetz
                            • Cipher
                              • May 2006
                              • 1309
                              I went back a few days ago and reduced the tray lift reverse time on all the fill levels for tray 1 A4 LEF.
                              The default values had worked fine for the first 30k of the machines life so I'm hoping only a minor pressure adjustment is required.
                              SP1908-005 -100 (100%)
                              SP1908-006 -100 (70%)
                              SP1908-007 -100 (30%)
                              SP1908-008 -150 (10%)
                              Fingers crossed.
