Mpc4502 wrinkling through fuser
  • mrfuser
    • 1622
    23768A34-C874-41F6-9C70-72E5B95C17FE.jpgOk, we can run letter thru fine, letter r , legal or ledger get a nasty wrinkle and you can hear it wrinkle as it passes thru fuser. Stop the page and before fuser no wrinkle, after there is a wrinkle. Tried a new stripper plate and still get this. Any ideas? I’m batting 0 for 2 today!
    seems like maybe paper is slowing down after it leaves fuser. Maybe an exit bind?
  • 1stcavvet
    • Apr 2015
    • 231
    Re: Mpc4502 wrinkling through fuser
    the rollers aren't straight the further the paper goes to the edges of the fuser the worse it is, check the bearings or where they mount GOOD LUCK
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Originally posted by mrfuser
      [ATTACH=CONFIG]39542[/ATTACH]
      The small white driven gears on the rear side of the exit assy might be gummed up where they sit on the shaft.
      Try taking them off and giving that area a wash.
      Failing that you can get the entire exit assy pretty cheaply as a part these days.
      • fshead
        • 2376
        fuser no wrinkle, after there is a wrinkle..
        hmmmmmmm must be fuser issue.......just replace the whole fuser
        • ridgemill
          • Sep 2017
          • 190
          This can be either one of the following:
          • Damp paper
          • Faulty PTR
          • Fuser duplex rollers stuck (if doing duplex)
          • Fuser entrance guide warped or dirty
          • Uneven fuser pressure
          • guitar9199
            • Sep 2016
            • 1100
            Had something similar once... turned out to be some toner buildup on the fuser ENTRANCE guide. It would cause a momentary "hang" in that area, letting the paper skew just enough to cause crinkle-folds (or Z-folds as they're sometimes called)
            Check your entrance and exit guides.
            • fshead
              • 2376
              what s the world coming to when "mr fuser cant "defeat a fuser unit
              • MIGUELMARCHENA
                • Feb 2018
                • 195
                the paper looks thin, it looks wavy
                wet paper and too much temperature for that thickness, maybe
                • copier tech
                  • 8172
                  Quote of the day! 10/10
                    • 37532
                    Don't judge a person by their handle. As an example, there is nothing slim about me now a days. It was a nickname the other kids called me in grade school. The type of thing that today's snowflakes would call bullying.
                    • guitar9199
                      • Sep 2016
                      • 1100
                      You can judge me by mine!!
                      I do play guitar, and I'm 91.99% sure I know what I'm doing!
                      • mrfuser
                        • 1622
                        I think I should change my handle to Mr. off-topic 🤪
                          • 37532
                          Does that mean that you're 8.01% incorrect?
                          • mrfuser
                            • 1622
                            Exact numbers! Amazing!!!
                              • 37532
                              Cut him some slack, he's only 57.
