Ricoh MPC 2051
  • Hoosierdaddy
    • Oct 2016
    • 182
    Ricoh MPC 2051
    Is there a fix for the fuser making that annoying noise after it quits making copies . (Other than rebuilding the fuser) I thought they had a firmware update for it.
    Thx Hoosierdaddy
  • copyaction
    • Oct 2007
    • 991
    Re: Ricoh MPC 2051
    SP 1121-001 from 100 to 0
    SP 1121-002 from 10 to 0
    SP 1121-003 from 10 to 0
    • cadillac2
      • Oct 2015
      • 42
      Re: Ricoh MPC 2051
      also there is this service bulletin: Fuser Vibration.pdf
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        Re: Ricoh MPC 2051
        Thx Hoosierdaddy
        Insufficient lubrication/grease on fuser sleeve. Some techs report success with high temp lithium grease instead of the pricier Ricoh grease. We replace the belt unit and follow the SP mode changes in the fuser vibration tech bulletin posted by cadillac2
        • copier tech
          • 8184
          Re: Ricoh MPC 2051
          I've used this on all my 2051's basically turns of idle rotation after the job finishes.
          However some customers did report the machine jams EVERY morning first copy, so the correct fix is to replace the fixing sleeve.
          • fshead
            • 2376
            Re: Ricoh MPC 2051
            i VE TAKEN some apart and re-lubed them and they are quiet but that is when i had free time
            to actually not take a short cut.
            The 3 1121 changing to 0 does the trick for the grinding noise.
            • fshead
              • 2376
              Re: Ricoh MPC 2051
              Originally posted by cadillac2
              also there is this service bulletin: [ATTACH]40067[/ATTACH]
              i read that bulletin i can say it does not even discuss the problem of lack of lubrication in the sleeve..
              Lowering temps can things go south fast.
              • Polarbear
                • Feb 2012
                • 1070
                Re: Ricoh MPC 2051
                This fusing unit was not Ricoh's proudest moment.
                This unit was poorly designed, in that there is a cloth covered bar that sits inside the fusing sleeve, where it contacts the pressure roller.
                When the cloth's lubrication dries up, the cloth binds to the inside of the sleeve, and deforms, causing a handbrake action against the sleeve = the foghorn noise that you hear when the sleeve turns.
                Lithium grease helps sometimes, if you catch the cloth before it deforms, because once it has starts to tear off the backing frame, it is not worth the effort.
                All the settings in the world will not help once the cloth starts tearing off the backing and making bulges between the sleeve and the sleeve support.
                When that happens, it is time for a new fuser unit.
                Press the GREEN button!!
                • Athlontini
                  • Jun 2012
                  • 269
                  Re: Ricoh MPC 2051
                  Here's another way of getting rid of the noise:
                  Add the fusing oil supply rollers to the fusing unit. Part# D105 4385. These will look similar to the ones in the MPC2050/2550. Comes as one complete assy, you simply snap out a metal bracket in the existing fuser and snap in the replacement oil roller assy. Only one time has this ever failed me in getting rid of the growling noise immediately.
                  Only downside is, I believe the price of the oil roller assy is close to that of the fusing sleeve.
                  • fshead
                    • 2376
                    Re: Ricoh MPC 2051
                    typical pay me now and pay me later...
                    • Stormhammer
                      • 150
                      Re: Ricoh MPC 2051
                      I can confirm that this will work. However, it only delays the inevitable.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: Ricoh MPC 2051
                        Oeps i'm a grave digger.
                        Dear Stormhammer, is D1054385 an ass'y for this, or do you need to order more parts?
                        Just want to let you know that sp1121 does not exist anymore after firmware upgrade!!!!
                        So, the only solution is to replace the sleeve or to add oil with this D1054385.
                        • Sabbatti
                          • Sep 2022
                          • 5
                          Re: Ricoh MPC 2051
                          Automatic Update Procedure with Ricoh Tool:
                          Automatic Rico Printer Firmware Update (Tested on Rico MP C2051)
                          Sabbatti
