MPC3003 print issues
  • digicor
    • Jul 2008
    • 1153
    I have a mpc3003 the connection picks up its own address in auto ip, i can ping it, its also bounces off of my mail server, i have green and amber lights
    NIC is set to 1,yet it wont print, it does have extended features, is there something in this I can change or shut off, or turn on? Is it supposed to have an SD card for print?(there is no sd card in it) i thought this didnt need print/scan sd cards anymore.
    Win 10 see's it and install's it, yet i could not web access it, i got the 404 error, but this may not mean its not accessible, the computer may be the issue,
    Any help with this would be greatly appreciated
  • copyaction
    • Oct 2007
    • 991
      • 37488
      Re: MPC3003 print issues
      Check that IEEE 802.1x for wireless is not enabled.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 469
        The MFP might have access control enabled on it.
        Print the interface setting print list (interface settings). Then look for access control. If present, assign that IP to your laptop and connect directly to the MFP. Remove the access control.
        Aye! Cut the crap
        • fshead
          • 2376
          if you try a static IP address"i use 192.168.1.177" and it reverts back to a 10.10.1.0 or close to that address then that IEEE 802.1x for wireless is enabled..
          I had it very recently and you can do a search here if you need more info...
          • copier tech
            • 8144
            When you send a print job does the data light briefly flash?
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              +1 FOR CHECKING THIS.
              • jonhiker
                • 661
                yep. had many a tech call me about not printing. Tell them to check that setting
                I will admit, i learned it the hard way
                  • 37488
                  SP 5801-011 Clear NCS will reset both back to factory settings. It will clear all other network settings so be ready to enter.
                  • digicor
                    • Jul 2008
                    • 1153
                    no it does not
                    • digicor
                      • Jul 2008
                      • 1153
                      thanks for all the suggestions, i will see about it tomorrow,9-4-2018
                      • fbkhan3
                        • May 2012
                        • 421
                        As it is already suggested ,access control could be a reason.
                        Telnet is your friend.
                        Telnet IP
                        Access Flush'
                        Logout
                        Regard's
                          • 37488
                          Telnet IP
                          Access Flush'
                          Logout
                          Regard's
                          SP 5801-011 is faster, easier and safer in the hands of an untrained idiot.
                          • digicor
                            • Jul 2008
                            • 1153
                            ok i tried these things
                            reset 5870 -3-1-4 in that order / no print
                            did an all clear/ no print
                            5801-11.. no print
                            yet it picks up its own ip address
                            no web access / 404 page not found
                            • StephenB
                              • Aug 2015
                              • 243
                              Try executing SP 5801-10, -20, and -25. If that does not work it may be restricted access. Which may be reset through the WIM.
                              I successfully changed one by reverting the IP ( on the Ricoh) to the original static address. Then using a network crossover cable, hook up a laptop directly to the Ricoh.
                              Assign the network adapter settings on the laptop using the Gateway, subnet mask and a close IP address to the Ricoh. Then you can access the WIM and reset the access restrictions on your Ricoh
