mpc2003 freez not inter sp mode
  • en.
    • Jul 2014
    • 124
    I have a problem with this device and it is not possible to enter sp mode only the screen appears but I can not enter after pressing system sp i did
    the following:
    Formate Hard Disk
    Replace the new hard
    I tried to update Java but iu did not updata
    Is there anyone encountered this problem and how do I recovery the java device
    best regards
  • keithxxiii
    Just a tech
    • Nov 2014
    • 471
    Re: mpc2003 freez not inter sp mode
    if you can access user tools, you can uninstall the java from there then go to SP mode and clear the value of SD1 from sp 5401. Make sure that java is not disabled from application invalidation.
    Aye! Cut the crap
    • davel
      • Oct 2011
      • 1107
      On 2003 you have to wait ages before you can access SP mode.
      • luca72
        • Oct 2017
        • 1791
        the following:
        Formate Hard Disk
        best regards
        if I understand correctly, you see the sp menu, but you can not get in, the machine takes a long time to enter the sp mode, especially at power on, if (as happened to me) continue to insist and press on the display does not do anything else that mess up, and you have to go out in copy mode, and then re-enter
        "I'll be back"
          • 37556
          My experience is that unless JAVA is stopped, will show as stopping, you have to wait until JAVA and any active Apps have finished loading before you can get into any SP mode or in User Tools anything except counter. On most models this can take 5 minutes or more. Since the MP C2003/2503 use a slower CPU, it might take 10 to 15 minutes after power on.
          • davel
            • Oct 2011
            • 1107
            If you can not enter SP mode how did you format HDD.
            • en.
              • Jul 2014
              • 124
              I have done my work in advance and without benefit
              • en.
                • Jul 2014
                • 124
                Very simple you take out the HDD out of machine and format it by pc or laptop
                • en.
                  • Jul 2014
                  • 124
                  i am waiting half our
                  • guitar9199
                    • Sep 2016
                    • 1100
                    Have you tried re-flashing the firmware?
                    • copier tech
                      • 8192
                      I agree fw issue.
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        the following:
                        Formate Hard Disk
                        best regards
                        The older model machines had Java(global scan) on the SD-Card in slot one.
                        I had a few sd-cards fall over because the (over zealous) java script writers software kept writing to the sd-card which eventually killed the sd-card. When the sd-card locked up the machine stalled in limbo waiting for the java to initialize.
                        I believe that java software bug at the time was eventually fixed.
                        I'm not sure how the java software/firmware is implemented in these newer model machines. I haven't had a look at it.
                        • en.
                          • Jul 2014
                          • 124
                          what do you mean re flashing and how ?
                            • 37556
                            It means reloading all firmware instead of updating. You have to use individual firmware modules and selecting every one.
                            • en.
                              • Jul 2014
                              • 124
                              ?than; you sir for your responding but i did firmware all package but when im choose any file its give sound (beep) and not respond
