MP C2003 SC240-04 LD Error Magenta
  • Lagonda
    • Aug 2008
    • 1649
    #16
    Re: MP C2003 SC240-04 LD Error Magenta
    Originally posted by JDYAL
    Just curious, if you go to the 7xx in service mode I think 7403, is the sc240-004 the only code that is showing recent. I've had a machine throw 2 codes simultaneously and in order to solve the issue had to resolve one sc before the other would clear. Hope that makes sense
    Ah ha! hadn't thought of that one. Should have remembered that trick as I've been caught out by that before, hang on while I check....................10 min later..........nope, only other code is SC650-14 as it can't talk to its RC Gate server cos its here in my workshop. Oh well, back to the drawing board
    • JDYAL
      • Sep 2008
      • 187
      #17
      Well dang! I was hoping it was another code that was holding you up. It's a head scratcher for sure. I'll ask around the shop for other suggestions
      • BLADE
        former propeller tester
        • 478
        #18
        ??? turn copier on and it goes straight to SC 240 even with a door open and the laser 5v safety line cut.
        text mode allows save to sd if machine don't print
          • 37653
          #19
          Originally posted by BLADE
          will the text mode do it?
          By text mode are you referring to SP 5992?
          • Lagonda
            • Aug 2008
            • 1649
            #20
            Ahh!! hadn't thought of that, might save my legs and back from standing in front of machine for hours as I work my way thru all the SP settings. Thanks
              • 37653
              #21
              If you go for All it is stil going to take awhile but you can sit down and wait. You also might want to setup Capturing the debug logs. Right after Address book Upload/Download in the C2003/C2503 service manual, probably the same place in the main CXX03 manual.
              • Lagonda
                • Aug 2008
                • 1649
                #22
                This is getting worse!!
                There is a spare MP C4503 in the workshop used for testing, training and a emergency spares source. Someone has had the laser unit out and now it's showing SC240-04 as well.
                • BLADE
                  • 478
                  #23
                  merry xmas to Karate Tech, Resentful Tech and yourself from everyone at CTN
                  • Lagonda
                    • Aug 2008
                    • 1649
                    #24
                    Think I might have found the some of the problem.......
                      • 37653
                      #25
                      [ATTACH=CONFIG]41329[/ATTACH]
                      I do believe that would definitely cause some type of problem.
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        #26
                        So who had the eproms out in the first place?
                        • Lagonda
                          • Aug 2008
                          • 1649
                          #27
                          Since it is Christmas and the season of good will to all men I shall diplomatically not name names. (but it wasn't me)
                          • Zaxxon
                            • 608
                            #28
                            The Elf of course
                            Please start you post with brand, model, problem.
                            • Lagonda
                              • Aug 2008
                              • 1649
                              #29
                              Found it!!!
                              After a lot of sweat, sleepless nights and high blood pressure we managed to get this box to suddenly remember it's supposed to be a photocopier.
                              First another set of NVRAM chips were fitted to replace the ones that had been fitted incorrectly but still got a SC240-04 code. Boss came up with the bright idea to zero the skew mirrors with SP 2118 then it would let you run SP 2110-5 to re-upload the setting info from the chip in the laser unit and bingo! away it went.
                              Couldn't find any reference to that in the manual and even NTS didn't know that trick.
                              • copier tech
                                • 8237
                                #30
                                Found it!!!
                                Thanks for the update, maybe SP2118 was the answer all along!
