ADF separator/reverse rollers crossover?
  • fshead
    • 2376
    hi
    I am curious on how many different sep rollers you guys keep in your tool bag.
    I am pretty much using the
    A859 2241 from the mp6001 on most machines."mpc2800,mpc2551,mpc3002,mpc3003"
    I know the feed belts are a bit different..
    Anyone see ant issues or suggestions?
  • anothertech
    • 1766
    Re: ADF separator/reverse rollers crossover?
    I use A859 2241 sep roller
    and A806 1295 belt
    in every machine that they will fit in. Seems to work ok, they have a short life and need to be replaced often.
    • morgansterne
      • Oct 2007
      • 83
      a8592241 should be interchangeable with d5412241. I've used a859 in newer D541 machines but probably not done the other way around.
      • fshead
        • 2376
        i saw mpc4503 SP DOC FEEDER had a bulletin for tearing feed belts and changed the belt.
        I think for that fast doc feeder i might not use the thinner belt,but how bout the sep roller?
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          I have put the A859 belts into those feeders when they have shredded the D541 belts. The "new" belts that start with D6 something I believe seem as able to shred as their predecessors.
          • fshead
            • 2376
            thanks for the feedback
            so does it pay to use the new modified belts?
            per bulletin..NOTE:
            With this part change, the material has been changed so as not to shift to one side easily
            D684 2171
            Being a much faster feeder i try not to improvise unless in a jam.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              per bulletin..NOTE:
              D684 2171
              I've had them shred the same way with the "improved" belts as well.
