ricoh mp5054 sc 687-00
  • digicor
    • Jul 2008
    • 1159
    is there a fix for this? Machine runs a few copies then throws this code , ill i have to reference is turn it off then turn it back on, Ive unplugged it for 15 mins, same story
    any ideas please, thankx
  • copier tech
    • 8222
    Re: ricoh mp5054 sc 687-00
    Not much info on this code.
    might be worth reseating the conntroller connections & ram.
    Flash firmware is worth a try.
    Code
    SC687-00
    Description
    PER Not Received Error Unable to receive the PER command from the controller.
    Causes
    Communication error
    Remedy
    • Turn the power off/on.
      • 37628
      Try re seating all USB connections.
      • ctuinstra
        • Apr 2011
        • 49
        We have the same issue on a 4054. Any resolution?
        • ctuinstra
          • Apr 2011
          • 49
          Never mind. It's the HDD. We have a couple of cases logged internally for this issue.
          • luca72
            • Oct 2017
            • 1792
            1) try to make copies with the HD disconnected
            2) try to do some sp 801-xxx
            3) update the firmware
            4) try to disconnect and reconnect the various boards, I never liked those microconnectors
            5) remove momentarly , fax board, or other option accessories
            "I'll be back"
