Ricoh MP C3001 firmware update
  • copytrust
    • Feb 2010
    • 118
    So this machine is in a new client i want it to update the firmware but it gives ne this error...... i have search the service manual did not find anything helpfull.pic4.jpg
    Any ideas guys??
  • anothertech
    • 1771
    Re: Ricoh MP C3001 firmware update
    Can you try updating it with an SD card? You'll probably have better luck that way.
    • copytrust
      • Feb 2010
      • 118
      Well.... i did try it. it gives download error E49
      • copier tech
        • 8235
        Originally posted by copytrust
        So this machine is in a new client i want it to update the firmware but it gives ne this error...... i have search the service manual did not find anything helpfull.[ATTACH=CONFIG]41641[/ATTACH]
        Any ideas guys??
        Are you using the correct remote firmware version? (not the same as the SD card/romdata version)
        • fshead
          • 2378
          Any ideas guys??
          Doing this for more years than i care to count and being an inde for a long time.
          What happens if while updating this new accnt FW you blow up the BICU and or controller unit.
          Its going to be you who has to eat the boards.
          And being you are not versed in these do you want to chance it.
          On old machine like that i only update the FW if it is totally needed..
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            On those old clunkers you MUST use an SD card 500mb or less.
            That would be your E49 error right there.
            Format an old PS card and use that for the FW update.
            • anothertech
              • 1771
              Check SP5886 to enable firmware update
              Check, User Tools-System Settings-Admin-Extended Security-Permit firmware update
                • 37641
                If you don't have an older 500MB or less SD card, you can use a software such as MiniTools Partition Wizard to create a 500MB partition on a larger card.
                • Zeldaman
                  • Mar 2011
                  • 946
                  Hi there! Yep, use a small sd-card. Then update "sys-copy", then "engine". After these 2 updates you can put the rest on the machine. A coworker make the mistake off updating the whole fw - after that he ahd a big doorstopper, the controller was bricked. Greetings...
                  • copytrust
                    • Feb 2010
                    • 118
                    Thank you all for your replies, i really appreciated.
                    i am using a 128MB sd card.
                    yes i am using the manual update firmware.
                    anothertech
                    i cant find that sp5886, also in the extended security there is no permit firmware.
                    • If you don't have an older 500MB or less SD card, you can use a software such as MiniTools Partition Wizard to create a 500MB partition on a larger card.
                    • i didnt know you can do that thats a great info, thanks
                      Now i have to say the machine works just fine, he could not scan on windows 10, thats why i went there for updating the machine.
                      I can always skip the update and program the machine to scan on FTP, instead SMB!!!!
                    • dalewb74
                      • Feb 2018
                      • 1167
                      as you probably already know be sure to put the sd card into the correct slot. one works and one doesn't for firmware updates.
                      • copytrust
                        • Feb 2010
                        • 118
                        Thank you for your repply, so there is an update on the problem,i tried almost everything on updating did not manage anything, so i back up the machine and made a memory clear, and there it is the machine is updating, i believe there was some kind of program blocking me.
